[求助] 全新安裝出錯(cuò) 請問什么原因
make[1]: *** [httpd] Error 1
make[1]: Leaving directory `/root/lanmp/httpd-2.2.22'
make: *** [all-recursive] Error 1
----Install Error: apache make err -----------
Centos 5.7
全新安裝lanmp v2.2.1,詳細(xì)按照官方教程安裝,最后一步出現(xiàn)下面的錯(cuò)誤
這樣看不出問題原因
回復(fù) 4# admin
Configuring extensions
checking size of long... (cached) 4
checking for int32_t... (cached) yes
checking for uint32_t... (cached) yes
checking for sys/types.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for strtoll... (cached) yes
checking for atoll... (cached) yes
checking for strftime... (cached) yes
checking whether to enable LIBXML support... yes
checking libxml2 install dir... no
checking for xml2-config path... (cached) /usr/local/bin/xml2-config
configure: error: xml2-config not found. Please check your libxml2 installation.
----Install Error: wdphp configure err -----------
yum install -y libxml2-devel
回復(fù) 6# admin
[root@localhost ~]# yum install -y libxml2-devel
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
   libxml2.so.2: cannot open shared object file: No such file or directory
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.4.3 (#1, Sep 21 2011, 20:06:00)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-51)]
If you cannot solve this problem yourself, please go to
the yum faq at:
  http://wiki.linux.duke.edu/YumFaq
怎么會(huì)有這樣的錯(cuò)誤提示,你的系統(tǒng)操作過什么或升級過什么?
我也出現(xiàn)同樣的錯(cuò)誤,不知道你們怎么解決的我
Centos5.8 32位,郁悶的要死。。。。。。。。!
