[求助] 阿里云的VPS上安裝失敗
直接安裝sh in.sh時
  1. useradd: user 'wdcpu' already exists
  2. installing mysql...
  3. checking build system type... x86_64-unknown-linux-gnu
  4. checking host system type... x86_64-unknown-linux-gnu
  5. checking target system type... x86_64-unknown-linux-gnu
  6. checking for a BSD-compatible install... /usr/bin/install -c
  7. checking whether build environment is sane... yes
  8. checking for a thread-safe mkdir -p... /bin/mkdir -p
  9. checking for gawk... gawk
  10. checking whether make sets $(MAKE)... no
  11. checking how to create a ustar tar archive... gnutar
  12. checking for style of include used by make... none
  13. checking for gcc... no
  14. checking for cc... no
  15. checking for cl.exe... no
  16. configure: error: in `/root/lanmp/mysql-5.1.61':
  17. configure: error: no acceptable C compiler found in $PATH
  18. See `config.log' for more details.
  19. ----Install Error: mysql configure err -----------
在網(wǎng)上搜了一下可能是少 gcc
結(jié)果yum install gcc時又有如下報錯
  1. Error: Package: glibc-headers-2.12-1.47.el6_2.12.x86_64 (updates)
  2.            Requires: kernel-headers >= 2.2.1
  3. Error: Package: glibc-headers-2.12-1.47.el6_2.12.x86_64 (updates)
  4.            Requires: kernel-headers
  5. You could try using --skip-broken to work around the problem
  6. ** Found 1 pre-existing rpmdb problem(s), 'yum check' output follows:
  7. kernel-2.6.32-220.13.1.el6.x86_64 has missing requires of kernel-firmware >= ('0
  8. ', '2.6.32', '220.13.1.el6')
求助
請修改文件vi /etc/yum.conf 將exclude=kernel*前加注釋即可解決
RPM 包安裝就沒有這個問題、我用編碼安裝也是這個問題、
RPM包安裝
sh lanmp_wdcp_ins.sh
就可以
卸載 (切記備份好數(shù)據(jù))
就可以
