[求助] 重新編譯php后重啟nginxd服務(wù)報(bào)錯(cuò),急!!
我想添加sockets模塊但重新編譯php后重啟nginxd服務(wù)報(bào)錯(cuò),php_fpm服務(wù)器起不來(lái)
[root@sky php-5.2.17]# service nginxd restart
Stopping nginx:                                            [  OK  ]
Shutting down php_fpm warning, no pid file found - php-fpm is not running ?
Starting nginx:                                            [  OK  ]
Starting php_fpm Error in argument 1, char 1: no argument for option -
Usage: php-cgi [-q] [-h] [-s] [-v] [-i] [-f <file>]
       php-cgi <file> [args...]
  -a               Run interactively
  -C               Do not chdir to the script's directory
  -c <path>|<file> Look for php.ini file in this directory
  -n               No php.ini file will be used
  -d foo[=bar]     Define INI entry foo with value 'bar'
  -e               Generate extended information for debugger/profiler
  -f <file>        Parse <file>.  Implies `-q'
  -h               This help
  -i               PHP information
  -l               Syntax check only (lint)
  -m               Show compiled in modules
  -q               Quiet-mode.  Suppress HTTP Header output.
  -s               Display colour syntax highlighted source.
  -v               Version number
  -w               Display source with stripped comments and whitespace.
  -z <file>        Load Zend extension <file>.
..............^C
下面是我重新編譯添加的參數(shù):
./configure --prefix=/www/wdlinux/php-5.2.17 --with-config-file-path=/www/wdlinux/etc --with-mysql=/www/wdlinux/mysql --with-iconv=/usr --with-freetype-dir --with-jpeg-dir --with-png-dir --with-zlib --with-libxml-dir=/usr --enable-xml --disable-rpath --enable-discard-path --enable-inline-optimization --with-curl --enable-mbregex --enable-mbstring --with-mcrypt=/usr --with-gd --enable-gd-native-ttf --with-openssl --with-mhash --enable-ftp --enable-sockets --enable-force-cgi-redirect --enable-fastcgi --enable-fpm  --with-fpm-conf=/www/wdlinux/etc/php-fpm.conf
其他地方?jīng)]有做任何修改,編譯的時(shí)候提示
configure: WARNING: unrecognized options: --enable-fpm, --with-fpm-conf
不知道為什么,管理員幫忙解決一下吧,網(wǎng)站都癱了,非常急,謝謝了。
先執(zhí)行
gzip -cd php-5.2.17-fpm-0.5.14.diff.gz | patch -fd php-5.2.17 -p1
cd php-5.2.17
./configure......
在哪個(gè)目錄下執(zhí)行g(shù)zip -cd php-5.2.17-fpm-0.5.14.diff.gz | patch -fd php-5.2.17 -p1
一直在等著您上線呢
不行啊,我已經(jīng)執(zhí)行這個(gè)命令
[root@sky lanmp]# pwd
/usr/src/lanmp/lanmp
[root@sky lanmp]# gzip -cd php-5.2.17-fpm-0.5.14.diff.gz | patch -fd php-5.2.17 -p1
執(zhí)行成功,然后
[root@sky lanmp]# cd php-5.2.17
[root@sky php-5.2.17]# ./configure --prefix=/www/wdlinux/php-5.2.17 --with-config-file-path=/www/wdlinux/etc --with-mysql=/www/wdlinux/mysql --with-iconv=/usr --with-freetype-dir --with-jpeg-dir --with-png-dir --with-zlib --with-libxml-dir=/usr --enable-xml --disable-rpath --enable-discard-path --enable-inline-optimization --with-curl --enable-mbregex --enable-mbstring --with-mcrypt=/usr --with-gd --enable-gd-native-ttf --with-openssl --with-mhash --enable-ftp --enable-sockets --enable-force-cgi-redirect --enable-fastcgi --enable-fpm  --with-fpm-conf=/www/wdlinux/etc/php-fpm.conf
還是報(bào)錯(cuò)
config.status: executing default commands
是不是我的編譯參數(shù)有問(wèn)題呢?
管理員大哥我給您發(fā)短消息了,您方便的話上我服務(wù)上看一下,謝謝了。
回復(fù) 5# skyjing
執(zhí)行成功,然后
有什么提示?
可否加你qq,你給我修復(fù)之后12:12左右恢復(fù)了,但現(xiàn)在數(shù)據(jù)庫(kù)報(bào)錯(cuò)連接不上
好了,恢復(fù)了,剛才不知道咋弄的mysql服務(wù)停止了,謝謝大哥了,一定幫大哥宣傳
我想問(wèn)一下您是怎么解決的呀
