[求助] wdcp系統(tǒng)管理面板登錄 無法訪問提示下載
長(zhǎng)度:89439947 (85M) [text/plain]
Saving to: `lanmp_wdcp-2-5.i386.rpm'
100%[======================================>] 89,439,947  89.1K/s   in 10m 32s
2015-01-28 09:02:06 (138 KB/s) - `lanmp_wdcp-2-5.i386.rpm' saved [89439947/89439947]
   1:lanmp_wdcp             ########################################### [100%]
Installing MySQL system tables...
OK
Filling help tables...
OK
To start mysqld at boot time you have to copy
support-files/mysql.server to the right place for your system
PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
To do so, start the server, then issue the following commands:
/www/wdlinux/mysql-5.1.63/bin/mysqladmin -u root password 'new-password'
/www/wdlinux/mysql-5.1.63/bin/mysqladmin -u root -h v157-7-113-200.z1d13.static.cnode.jp password 'new-password'
Alternatively you can run:
/www/wdlinux/mysql-5.1.63/bin/mysql_secure_installation
which will also give you the option of removing the test
databases and anonymous user created by default.  This is
strongly recommended for production servers.
See the manual for more instructions.
You can start the MySQL daemon with:
cd /www/wdlinux/mysql-5.1.63 ; /www/wdlinux/mysql-5.1.63/bin/mysqld_safe &
You can test the MySQL daemon with mysql-test-run.pl
cd /www/wdlinux/mysql-5.1.63/mysql-test ; perl mysql-test-run.pl
Please report any problems with the /www/wdlinux/mysql-5.1.63/bin/mysqlbug script!
Starting MySQL.Manager of pid-file quit without updating file.[失敗]
error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)'
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
ln: “/usr/lib/plugin”:無法覆蓋目錄
啟動(dòng) httpd:[確定]
啟動(dòng) nginx:nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
[失敗]
啟動(dòng) httpd:
啟動(dòng) pure-config.pl:Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
============  lanmp_wdcp install OK  ==============
          visit http://ip
          wdcp visit http://ip:8080
          more infomation please visit http://www.gps-cemuyi.cn
登陸phpmyadmin創(chuàng)建數(shù)據(jù)庫wdcpdb數(shù)據(jù)
B 檢查/www/wdlinux/mysql/var/下有沒wdcpd目錄及目錄下是否有文件
如果沒有
可手工在phpmyadmin創(chuàng)建數(shù)據(jù)庫wdcpdb數(shù)據(jù)庫,及wdcp用戶并把信息保存到/www/wdlinux/wdcp/data/db.inc.php文件中
同時(shí)將/www/wdlinux/wdcp/wdcpdb.sql文件導(dǎo)入
完成
不會(huì)使用手工在phpmyadmin創(chuàng)建數(shù)據(jù)庫 管理員能發(fā)具體操作么?感謝
wdcp支持兩種安裝方式 1 源碼編譯此安裝比較麻煩和耗時(shí),一般是20分鐘至一個(gè)小時(shí)不等,具體視機(jī)器配置情況而定 2 RPM包安裝簡(jiǎn)單快速,下載快的話,幾分鐘就可以完成 源碼安裝(ssh登錄服務(wù)器,
執(zhí)行如下操作即可,需root用戶身份安裝)
tar zxvf lanmp_laster.tar.gz
sh install.sh
4個(gè)可選安裝,如下圖
4 是安裝所有,即可在wdcp的后臺(tái)里自由切換nginx,apache,nginx+apache的應(yīng)用環(huán)境
卸載(注意備份數(shù)據(jù),否則后果自負(fù))
sh install.sh uninstall
就可以
RPM包安裝
sh lanmp_wdcp_ins.sh
就可以
RPM包安裝支持系統(tǒng):CentOS 5.X/wdlinux_base 5.X/wdOS 1.0,CentOS 6.X ,32位,64位均支持
卸載 (切記備份好數(shù)據(jù))
sh lanmp_wdcp_ins.sh uninstall
就可以
安裝完后,默認(rèn)的后臺(tái)管理地址如下
http://ip:8080
用戶名:admin 默認(rèn)密碼:wdlinux.cn
mysql默認(rèn)的管理用戶名:root 默認(rèn)密碼:wdlinux.cn
相關(guān)說明
所有軟件安裝目錄/www/wdlinux
站點(diǎn)配置文件
/www/wdlinux/nginx/conf/vhost
數(shù)據(jù)庫數(shù)據(jù)文件目錄 /www/wdlinux/mysql/var
可能問題
1 登錄時(shí)提示超時(shí),檢查下系統(tǒng)時(shí)間是否為當(dāng)前時(shí)間
2 重裝后重新打開IE,否則會(huì)有session錯(cuò)誤提示的問題
安裝wdCP,無法連接mysql,解決方法
在ubuntu 12.04版本上安裝wdCP,采用編譯安裝的方式,一路裝下來最后悲催地報(bào)錯(cuò)了:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) 無法連接mysql,請(qǐng)檢查mysql是否已啟動(dòng)及用戶密碼是否設(shè)置正確!:
* Restarting web server httpd
去/tmp目錄下找了找還真沒有mysql.sock,用netstat–lnpt也沒發(fā)現(xiàn)那個(gè)占用3306端口的吃貨,你妹的mysql就沒啟動(dòng)起來啊。
根據(jù)網(wǎng)上消息,/etc/my.cnf中的basedir、datadir、user是要正確填寫滴,不寫是容易出錯(cuò)滴。用vi一看,果然沒有這幾貨。
不過似乎basedir和datadir不填也行,只需要填寫user=root即可,如下:
[mysqld]
user = root
port = 3306
socket = /tmp/mysql.sock
然后重啟一下mysql:
servicemysqld restart
這回mysql終于啟動(dòng)了,netstat–lnpt也能發(fā)現(xiàn)有3306端口了。但此時(shí)訪問wdCP主頁(http://ip:8080)還是會(huì)報(bào)錯(cuò),打開頁面就是:
這時(shí)先用wdcp的工具重新設(shè)置一下數(shù)據(jù)庫的root密碼和wdcp密碼:
sh /www/wdlinux/tools/mysql_root_chg.sh
會(huì)顯示重置之后的root密碼
sh /www/wdlinux/tools/mysql_wdcp_chg.sh
會(huì)顯示重置之后的wdcp密碼
重置之后,終于好不容易能從phpMyAdmin訪問數(shù)據(jù)庫了,用戶root,密碼為上文返回值,訪問地址為:
http://ip:8080/phpmyadmin/
在phpmyadmin中創(chuàng)建個(gè)用戶wdcp,密碼為上文所述,權(quán)限全選。此時(shí)再訪問wdCP會(huì)發(fā)
現(xiàn)字符終于有了點(diǎn)變化,嚯嚯嚯嚯:
MySQL Query Error:select * from wd_conf where name='os_rl'
再去phpmyadmin中創(chuàng)建一個(gè)名為wdcpdb的數(shù)據(jù)庫,把/www/wdlinux/wdcp/wdcpdb.sql拷出來,導(dǎo)入數(shù)據(jù)庫。
此時(shí)再訪問wdcp主頁,發(fā)現(xiàn)眼前一亮,終于登陸界面出現(xiàn)了,輸入用戶名admin,密碼wdlinux.cn,爽去吧騷年….
