[求助] 更新了php的遠(yuǎn)程DOS漏洞 php-fpm啟動不了啊
按照這個http://www.gps-cemuyi.cn/bbs/thread-38462-1-1.html 操作的
Stopping nginx: [  OK  ]
Shutting down php_fpm . done
Starting nginx: [  OK  ]
       php-cgi <file> [args...]
  -a               Run interactively
  -C               Do not chdir to the script's directory
  -n               No php.ini file will be used
  -d foo[=bar]     Define INI entry foo with value 'bar'
  -e               Generate extended information for debugger/profiler
  -f <file>        Parse <file>.  Implies `-q'
  -h               This help
  -i               PHP information
  -l               Syntax check only (lint)
  -m               Show compiled in modules
  -q               Quiet-mode.  Suppress HTTP Header output.
  -s               Display colour syntax highlighted source.
  -v               Version number
  -w               Display source with stripped comments and whitespace.
  -z <file>        Load Zend extension <file>.
................................... failed
嘻嘻嘻嘻嘻嘻嘻嘻嘻嘻嘻嘻嘻
