[求助] centos 7 x64使用最新的wdcp然后mysql會(huì)自己關(guān)閉
網(wǎng)站用著用著數(shù)據(jù)庫(kù)就自動(dòng)關(guān)閉了我先把錯(cuò)誤代碼貼出了
  1. 160518 16:29:49 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.5.48/data
  2. 160518 16:29:49 [Warning] 'THREAD_CONCURRENCY' is deprecated and will be removed in a future release.
  3. 160518 16:29:49 [Warning] 'THREAD_CONCURRENCY' is deprecated and will be removed in a future release.
  4. 160518 16:29:49 [Note] /www/wdlinux/mysql-5.5.48/bin/mysqld (mysqld 5.5.48) starting as process 25559 ...
  5. 160518 16:29:49 [Note] Plugin 'FEDERATED' is disabled.
  6. 160518 16:29:49 InnoDB: The InnoDB memory heap is disabled
  7. 160518 16:29:49 InnoDB: Mutexes and rw_locks use GCC atomic builtins
  8. 160518 16:29:49 InnoDB: Compressed tables use zlib 1.2.7
  9. 160518 16:29:49 InnoDB: Initializing buffer pool, size = 100.0M
  10. 160518 16:29:49 InnoDB: Completed initialization of buffer pool
  11. 160518 16:29:50 InnoDB: highest supported file format is Barracuda.
  12. InnoDB: The log sequence number in ibdata files does not match
  13. InnoDB: the log sequence number in the ib_logfiles!
  14. 160518 16:29:50  InnoDB: Database was not shut down normally!
  15. InnoDB: Starting crash recovery.
  16. InnoDB: Reading tablespace information from the .ibd files...
  17. InnoDB: Restoring possible half-written data pages from the doublewrite
  18. InnoDB: buffer...
  19. 160518 16:29:50  InnoDB: Waiting for the background threads to start
  20. 160518 16:29:51 InnoDB: 5.5.48 started; log sequence number 1670874
  21. 160518 16:29:51 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
  22. 160518 16:29:51 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
  23. 160518 16:29:51 [Note] Server socket created on IP: '0.0.0.0'.
  24. 160518 16:29:51 [Note] Event Scheduler: Loaded 0 events
  25. 160518 16:29:51 [Note] /www/wdlinux/mysql-5.5.48/bin/mysqld: ready for connections.
  26. Version: '5.5.48'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
我看了下好像是說內(nèi)存大小不夠,但是服務(wù)器的內(nèi)存實(shí)際上是夠的,請(qǐng)問怎么回事
確實(shí)遇到這樣的問題,我的也遇到.每次都需要手動(dòng)啟動(dòng)mysql.
回復(fù) 2# shy_kevin
   是不是 wdcp v3的問題 老是這樣的話怎么能行 網(wǎng)站根本沒法弄
v3只是一個(gè)獨(dú)立的后臺(tái)管理,跟mysql有什么關(guān)聯(lián)?
回復(fù) 4# admin
    老大,這個(gè)問題確實(shí)存在.每次都需要重啟mysql.要不然就不行,以前沒有遇到過這樣的問題.
回復(fù) 3# d87904488
    我也在懷疑,每次網(wǎng)站打不開,都需要進(jìn)入V3里面重啟mysql才可以.我也是裝的centos7.0以前的版本從來沒有發(fā)現(xiàn)這個(gè)問題.
我也有,wp的程序會(huì)出現(xiàn),其他暫時(shí)沒發(fā)現(xiàn)
后知后覺
我之前也是 ,添加swap就好了
123123
我也是這個(gè)問題,每天都要手動(dòng)開啟mysql服務(wù)就好了
swap 搞定 沒問題
yeyali.com
