[求助] 安裝3.1時(shí)到了mysql出現(xiàn)很多警告。如:未初始化。未使用變量。。。。
/root/src/mysql-5.5.49/client/mysqltest.cc: In function ‘char* re_eprint(int)’:
/root/src/mysql-5.5.49/client/mysqltest.cc:8091: 警告:未使用的變量‘len’
[ 89%] Building CXX object sql/CMakeFiles/sql.dir/key.cc.o
[ 89%] Building CXX object sql/CMakeFiles/sql.dir/log.cc.o
Linking CXX executable mysqltest_embedded
/root/src/mysql-5.5.49/sql/log.cc: In member function ‘void LOGGER::deactivate_log_handler(THD*, uint)’:
/root/src/mysql-5.5.49/sql/log.cc:1441: 警告:此函數(shù)中的‘file_log’在使用前可能未初始化
[ 89%] Building CXX object sql/CMakeFiles/sql.dir/lock.cc.o
[ 89%] [ 89%] Built target mysqltest_embedded
Building CXX object sql/CMakeFiles/sql.dir/log_event.cc.o
[ 89%] Building CXX object sql/CMakeFiles/sql.dir/rpl_record.cc.o
[ 89%] Building CXX object sql/CMakeFiles/sql.dir/rpl_reporting.cc.o
[ 90%] Building CXX object sql/CMakeFiles/sql.dir/log_event_old.cc.o
[ 90%] Building CXX object sql/CMakeFiles/sql.dir/rpl_record_old.cc.o
[ 90%] Building CXX object sql/CMakeFiles/sql.dir/mf_iocache.cc.o
[ 90%] Building CXX object sql/CMakeFiles/sql.dir/my_decimal.cc.o
[ 90%] Building C object sql/CMakeFiles/sql.dir/__/sql-common/my_time.c.o
[ 90%] Building CXX object sql/CMakeFiles/sql.dir/mysqld.cc.o
[ 90%] Building CXX object sql/CMakeFiles/sql.dir/net_serv.cc.o
[ 90%] Building CXX object sql/CMakeFiles/sql.dir/keycaches.cc.o
[ 90%] Building C object sql/CMakeFiles/sql.dir/__/sql-common/client_plugin.c.o
[ 90%] Building CXX object sql/CMakeFiles/sql.dir/opt_range.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/opt_sum.cc.o
[ 91%] Building C object sql/CMakeFiles/sql.dir/__/sql-common/pack.c.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/parse_file.cc.o
[ 91%] Building C object sql/CMakeFiles/sql.dir/password.c.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/procedure.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/protocol.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/records.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/repl_failsafe.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/rpl_filter.cc.o
[ 91%] Building CXX object sql/CMakeFiles/sql.dir/set_var.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/slave.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/sp.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/sp_cache.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/sp_head.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/sp_pcontext.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/sp_rcontext.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/spatial.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/sql_acl.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/sql_analyse.cc.o
[ 92%] Building CXX object sql/CMakeFiles/sql.dir/sql_base.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_cache.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_class.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_client.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_crypt.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_cursor.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_db.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_delete.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_derived.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_do.cc.o
[ 93%] Building CXX object sql/CMakeFiles/sql.dir/sql_error.cc.o
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_handler.cc.o
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_help.cc.o
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_insert.cc.o
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_lex.cc.o
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_list.cc.o
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_load.cc.o
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_manager.cc.o
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_parse.cc.o
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_partition.cc.o
/root/src/mysql-5.5.49/sql/sql_partition.cc: In function ‘int get_part_iter_for_interval_cols_via_map(partition_info*, bool, uint32*, uchar*, uchar*, uint, uint, uint, PARTITION_ITERATOR*)’:
/root/src/mysql-5.5.49/sql/sql_partition.cc:7627: 警告:此函數(shù)中的‘get_col_endpoint’在使用前可能未初始化
[ 94%] Building CXX object sql/CMakeFiles/sql.dir/sql_plugin.cc.o
[ 95%] Building CXX object sql/CMakeFiles/sql.dir/sql_prepare.cc.o
[ 95%] Building CXX object sql/CMakeFiles/sql.dir/sql_rename.cc.o
[ 95%] Building CXX object sql/CMakeFiles/sql.dir/debug_sync.cc.o
[ 95%] Building CXX object sql/CMakeFiles/sql.dir/sql_repl.cc.o
[ 95%] Building CXX object sql/CMakeFiles/sql.dir/sql_select.cc.o
/root/src/mysql-5.5.49/sql/sql_repl.cc: In function ‘bool log_in_use(const char*)’:
/root/src/mysql-5.5.49/sql/sql_repl.cc:253: 警告:建議在空的‘if’語句體周圍加上花括號(hào)
[ 95%] Building CXX object sql/CMakeFiles/sql.dir/sql_show.cc.o
[ 95%] Building C object sql/CMakeFiles/sql.dir/sql_state.c.o
[ 95%] Building CXX object sql/CMakeFiles/sql.dir/sql_string.cc.o
[ 95%] Building CXX object sql/CMakeFiles/sql.dir/sql_table.cc.o
[ 95%] Building CXX object sql/CMakeFiles/sql.dir/sql_test.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/sql_trigger.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/sql_udf.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/sql_union.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/sql_update.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/sql_view.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/strfunc.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/table.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/thr_malloc.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/sql_time.cc.o
[ 96%] Building CXX object sql/CMakeFiles/sql.dir/tztime.cc.o
[ 97%] Building CXX object sql/CMakeFiles/sql.dir/uniques.cc.o
[ 97%] Building CXX object sql/CMakeFiles/sql.dir/unireg.cc.o
[ 97%] Building CXX object sql/CMakeFiles/sql.dir/item_xmlfunc.cc.o
^Cmake[2]: *** [sql/CMakeFiles/sql.dir/unireg.cc.o] 中斷
make[2]: *** [sql/CMakeFiles/sql.dir/item_xmlfunc.cc.o] 中斷
make[1]: *** [sql/CMakeFiles/sql.dir/all] 中斷
make: *** [all] 中斷
這樣正常嗎?應(yīng)該怎么設(shè)置,是系統(tǒng)的問題,還是什么問題?   Centos 6.4 64位
正在學(xué)習(xí)
正常的,中人沒安裝沒中斷就沒問題
