[求助] ----Install Error: apache make err ---
Building shared: mod_slotmem_shm.la
/www/wdsetup/src/httpd-2.4.18/srclib/apr/libtool --silent --mode=link gcc -std=gnu99  -g -O2 -pthread         -o httpd  modules.lo buildmark.o -export-dynamic server/libmain.la modules/core/libmod_so.la modules/http/libmod_http.la server/mpm/prefork/libprefork.la os/unix/libos.la -lpcre    /www/wdsetup/src/httpd-2.4.18/srclib/apr-util/libaprutil-1.la /www/wdsetup/src/httpd-2.4.18/srclib/apr-util/xml/expat/libexpat.la -liconv /www/wdsetup/src/httpd-2.4.18/srclib/apr/libapr-1.la -lrt -lcrypt -lpthread
make[4]: Entering directory `/www/wdsetup/src/httpd-2.4.18/modules/slotmem'
make[4]: Nothing to be done for `local-shared-build'.
make[4]: Leaving directory `/www/wdsetup/src/httpd-2.4.18/modules/slotmem'
make[3]: Leaving directory `/www/wdsetup/src/httpd-2.4.18/modules/slotmem'
make[3]: Entering directory `/www/wdsetup/src/httpd-2.4.18/modules/ssl'
Building shared: mod_ssl.la
make[4]: Entering directory `/www/wdsetup/src/httpd-2.4.18/modules/ssl'
/www/wdsetup/src/httpd-2.4.18/srclib/apr/libtool --silent --mode=link gcc -std=gnu99  -g -O2 -pthread    -lssl -lcrypto -lrt -lcrypt -lpthread       -o mod_ssl.la -rpath /www/wdlinux/httpd-2.4.18/modules -module -avoid-version  mod_ssl.lo ssl_engine_config.lo ssl_engine_init.lo ssl_engine_io.lo ssl_engine_kernel.lo ssl_engine_log.lo ssl_engine_mutex.lo ssl_engine_pphrase.lo ssl_engine_rand.lo ssl_engine_vars.lo ssl_scache.lo ssl_util_stapling.lo ssl_util.lo ssl_util_ssl.lo ssl_engine_ocsp.lo ssl_util_ocsp.lo  -export-symbols-regex ssl_module
.libs/mod_ssl.o: could not read symbols: File in wrong format
make[4]: *** [mod_ssl.la] Error 1
make[4]: Leaving directory `/www/wdsetup/src/httpd-2.4.18/modules/ssl'
make[3]: *** [shared-build-recursive] Error 1
make[3]: Leaving directory `/www/wdsetup/src/httpd-2.4.18/modules/ssl'
make[2]: *** [shared-build-recursive] Error 1
make[2]: Leaving directory `/www/wdsetup/src/httpd-2.4.18/modules'
make[1]: *** [shared-build-recursive] Error 1
make[1]: *** Waiting for unfinished jobs....
server/.libs/libmain.a: could not read symbols: File in wrong format
make[1]: *** [httpd] Error 1
make[1]: Leaving directory `/www/wdsetup/src/httpd-2.4.18'
make: *** [all-recursive] Error 1
x86_64
CentOS release 6.5 (Final)
----Install Error: apache make err -----------
系統(tǒng)是CentOS6.5的X64版本.最小化桌面安裝的..wdcp是按照最新的3.1安裝..提示上面的錯(cuò)誤..
安裝使用的是默認(rèn)安裝..選擇的1 (lamp)..之前還有報(bào)錯(cuò)..大體的按照這個(gè)教程修復(fù)了...
http://blog.csdn.net/kkdelta/article/details/7740370
然后報(bào)錯(cuò)在這一步..確實(shí)不知道是什么問題了..請(qǐng)幫助看看.....
aa
