AI導航網(wǎng)AI應用網(wǎng)站大全 wdcp官方技術(shù)支持/服務(wù) 阿里云8折優(yōu)惠券 無敵云 騰訊云優(yōu)惠中,現(xiàn)注冊更有260代金額券贈送
[求助] 菜鳥新手求助
這個掛載成功了嗎,要怎么掛載。
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x9d244654
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *           1          64      512000   83  Linux
Partition 1 does not end on cylinder boundary.
/dev/sda2              64       60802   487873536   8e  Linux LVM
Disk /dev/mapper/VolGroup-lv_root: 53.7 GB, 53687091200 bytes
255 heads, 63 sectors/track, 6527 cylinders
Disk identifier: 0x00000000
Disk /dev/mapper/VolGroup-lv_swap: 6241 MB, 6241124352 bytes
255 heads, 63 sectors/track, 758 cylinders
Disk /dev/mapper/VolGroup-lv_home: 439.7 GB, 439651139584 bytes
255 heads, 63 sectors/track, 53451 cylinders
Last login: Fri Aug 19 01:16:30 2016 from 116.1.78.24
[root@localhost ~]# df -h
Filesystem                    Size  Used Avail Use% Mounted on
/dev/mapper/VolGroup-lv_root   50G  2.1G   45G   5% /
tmpfs                         2.9G     0  2.9G   0% /dev/shm
/dev/sda1                     485M   33M  427M   8% /boot
/dev/mapper/VolGroup-lv_home  404G  199M  383G   1% /home
[root@localhost ~]#
是這個吧
[root@localhost ~]#
是這個吧
