2 做過哪些操作或改動設置等
[求助] 安裝出現(xiàn)問題
checking size of size_t... 4
checking size of long long... 8
checking size of long long int... 8
checking size of long... 4
checking size of int... 4
checking size of intmax_t... 8
checking size of ssize_t... 4
checking size of ptrdiff_t... 4
checking for st_blksize in struct stat... yes
checking for st_blocks in struct stat... yes
checking for st_rdev in struct stat... yes
checking for size_t... yes
checking for uid_t in sys/types.h... yes
checking for struct sockaddr_storage... yes
checking for field sa_len in struct sockaddr... no
checking for IPv6 support... yes
checking for vprintf... yes
checking for alphasort... yes
checking for asctime_r... yes
checking for chroot... yes
checking for ctime_r... yes
checking for cuserid... yes
checking for crypt... no
checking for flock... yes
checking for ftok... yes
checking for funopen... no
checking for gai_strerror... yes
checking for gcvt... yes
checking for getloadavg... yes
checking for getlogin... yes
checking for getprotobyname... yes
checking for getprotobynumber... yes
checking for getservbyname... yes
checking for getservbyport... yes
checking for getrusage... yes
checking for gettimeofday... yes
checking for gmtime_r... yes
checking for getpwnam_r... yes
checking for getgrnam_r... yes
checking for getpwuid_r... yes
checking for grantpt... yes
checking for inet_ntoa... yes
checking for inet_ntop... yes
checking for inet_pton... yes
checking for isascii... yes
checking for link... yes
checking for localtime_r... yes
checking for lockf... yes
checking for lchown... yes
checking for lrand48... yes
checking for memcpy... yes
checking for memmove... yes
checking for mkstemp... yes
checking for mmap... yes
checking for nl_langinfo... yes
checking for perror... yes
checking for poll... yes
checking for ptsname... yes
checking for putenv... yes
checking for realpath... yes
checking for random... yes
checking for rand_r... yes
checking for regcomp... yes
checking for res_search... (cached) yes
checking for scandir... yes
checking for setitimer... yes
checking for setlocale... yes
checking for localeconv... yes
checking for setenv... yes
checking for setpgid... yes
checking for setsockopt... yes
checking for setvbuf... yes
checking for shutdown... yes
checking for sin... yes
checking for snprintf... yes
checking for srand48... yes
checking for srandom... yes
checking for statfs... yes
checking for statvfs... yes
checking for std_syslog... no
checking for strcasecmp... yes
checking for strcoll... yes
checking for strdup... yes
checking for strerror... yes
checking for strftime... yes
checking for strnlen... yes
checking for strptime... yes
checking for strstr... yes
checking for strtok_r... yes
checking for symlink... yes
checking for tempnam... yes
checking for tzset... yes
checking for unlockpt... yes
checking for unsetenv... yes
checking for usleep... yes
checking for utime... yes
checking for vsnprintf... yes
checking for nanosleep... checking for nanosleep in -lrt... yes
yes
checking for getaddrinfo... yes
checking for strlcat... no
checking for strlcpy... no
checking for getopt... yes
checking whether utime accepts a null argument... yes
checking for working alloca.h... (cached) yes
checking for alloca... yes
checking for declared timezone... yes
checking for type of reentrant time-related functions... POSIX
checking for readdir_r... yes
checking for type of readdir_r... POSIX
checking for in_addr_t... yes
checking for crypt_r... no
General settings
checking whether to include gcov symbols... no
checking whether to include debugging symbols... no
checking layout of installed files... PHP
checking path to configuration file... DEFAULT
checking where to scan for configuration files...
checking whether to enable safe mode by default... no
checking for safe mode exec dir... /usr/local/php/bin
checking whether to enable PHP's own SIGCHLD handler... no
checking whether to enable magic quotes by default... no
checking whether to explicitly link against libgcc... no
checking whether to enable short tags by default... yes
checking whether to enable dmalloc... no
checking whether to enable IPv6 support... yes
checking how big to make fd sets... using system default
Configuring extensions
checking size of long... (cached) 4
checking for int32_t... yes
checking for uint32_t... yes
checking for sys/types.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for strtoll... yes
checking for atoll... yes
checking for strftime... (cached) yes
checking whether to enable LIBXML support... yes
checking libxml2 install dir... no
checking for xml2-config path... /usr/bin/xml2-config
checking whether libxml build works... yes
checking for OpenSSL support... no
checking for Kerberos support... no
checking for PCRE support... yes
checking for ZLIB support... no
checking if the location of ZLIB install directory is defined... no
checking whether to enable bc style precision math functions... no
checking for BZip2 support... no
checking whether to enable calendar conversion support... no
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking if we should use cURL for url streams... no
checking for cURL in default path... found in /usr
checking for cURL 7.10.5 or greater... libcurl 7.15.5
checking for SSL support in libcurl... yes
checking how to run the C preprocessor... gcc -E
checking for openssl support in libcurl... yes
checking for openssl/crypto.h... yes
checking for gnutls support in libcurl... no
checking for curl_easy_perform in -lcurl... yes
checking for curl_version_info in -lcurl... yes
checking for curl_easy_strerror in -lcurl... yes
checking for curl_multi_strerror in -lcurl... yes
checking for QDBM support... no
checking for GDBM support... no
checking for NDBM support... no
checking for Berkeley DB4 support... no
checking for Berkeley DB3 support... no
checking for Berkeley DB2 support... no
checking for DB1 support... no
checking for DBM support... no
checking for CDB support... no
checking for INI File support... no
checking for FlatFile support... no
checking whether to enable DBA interface... no
checking whether to enable dbase support... no
checking whether to enable DOM support... yes
checking for xml2-config path... (cached) /usr/bin/xml2-config
checking whether libxml build works... (cached) yes
checking whether to enable EXIF (metadata from images) support... no
checking for FrontBase SQL92 (fbsql) support... no
checking for FDF support... no
checking whether to enable input filter support... yes
checking pcre install prefix... no
checking whether to enable FTP support... yes
checking OpenSSL dir for FTP... no
checking for GD support... yes
checking for the location of libjpeg... no
checking for the location of libpng... no
checking for the location of libXpm... no
checking for FreeType 1.x support... no
checking for FreeType 2... no
checking for T1lib support... no
checking whether to enable truetype string function in GD... yes
checking whether to enable JIS-mapped Japanese font support in GD... no
checking for fabsf... yes
checking for floorf... yes
If configure fails try --with-jpeg-dir=<DIR>
checking for png_write_image in -lpng... yes
If configure fails try --with-xpm-dir=<DIR>
If configure fails try --with-freetype-dir=<DIR>
checking for GNU gettext support... no
checking for GNU MP support... no
checking whether to enable hash support... yes
checking whether byte ordering is bigendian... (cached) no
checking size of short... 2
checking size of long long... (cached) 8
checking for iconv support... yes
configure: error: Please reinstall the iconv library.
----Install Error: wdphp configure err -----------
[root@1212-1-6/bampu ~]#
請官方看看 這是怎么啦
