[求助] mysql升級(jí)為5.5后的奇怪問(wèn)題
CentOs6.2 64bit,裝了lamp,因?yàn)橛玫降囊粋(gè)軟件必須要php 5.3以上版本,所以根據(jù)論壇里的方法開始折騰。
先升級(jí)到了mysql 5.5,升級(jí)成功,phpmyadmin中提示server版本是5.5.27,client版本是5.1。然后升級(jí)php 5.3,不管怎么折騰都不成功。翻遍論壇,有個(gè)朋友說(shuō)一定要先升級(jí)mysql然后再升級(jí)php5.3。幸好做了快照,再次折騰。
先升級(jí)php 5.3,裝了一些要用到的externsion。然后升級(jí)mysql 5.5,當(dāng)然,肯定不成功的,幸好論壇里關(guān)于php和mysql升級(jí)的帖子翻得都爛了,修改/www/wdlinux/init.d/mysqld文件如下:
        basedir = /www/wdlinux/mysql
        datadir= /www/wdlinux/mysql/var
mysqld啟動(dòng)起來(lái)了。但還有問(wèn)題:
phpmyadmin里面顯示server和client都是5.1版本,但是服務(wù)器上用mysqld -V查看顯示:
        mysqld  Ver 5.5.27 for Linux on x86_64 (Source distribution)
查看/www/wdlinux/mysql-5.5.27/var里面的err文件,顯示:
        130524 15:07:40 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql/var
        130524 15:07:40 InnoDB: The InnoDB memory heap is disabled
        130524 15:07:40 InnoDB: Mutexes and rw_locks use GCC atomic builtins
        130524 15:07:40 InnoDB: Compressed tables use zlib 1.2.3
        130524 15:07:40 InnoDB: Initializing buffer pool, size = 128.0M
        130524 15:07:40 InnoDB: Completed initialization of buffer pool
        130524 15:07:40 InnoDB: highest supported file format is Barracuda.
        130524 15:07:40  InnoDB: Waiting for the background threads to start
        130524 15:07:41 InnoDB: 1.1.8 started; log sequence number 1595675
        130524 14:58:22 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
        130524 14:58:22 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
        130524 14:58:22 [Note] Server socket created on IP: '0.0.0.0'.
        130524 15:07:41 [ERROR] Missing system table mysql.proxies_priv; please run mysql_upgrade to create it
        130524 15:07:41 [Note] Event Scheduler: Loaded 0 events
        130524 15:07:41 [Note] /www/wdlinux/mysql/bin/mysqld: ready for connections.
        Version: '5.5.27'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
修改/www/wdlinux/etc/my.cnf文件,在[mysqld]下面加入
        bind-address    = 127.0.0.1
再執(zhí)行
        mysql_upgrade -u root -p
都是OK。重啟mysqld,查看err文件:
        130524 15:16:47 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql/var
        130524 15:16:47 InnoDB: The InnoDB memory heap is disabled
        130524 15:16:47 InnoDB: Mutexes and rw_locks use GCC atomic builtins
        130524 15:16:47 InnoDB: Compressed tables use zlib 1.2.3
        130524 15:16:47 InnoDB: Initializing buffer pool, size = 128.0M
        130524 15:16:47 InnoDB: Completed initialization of buffer pool
        130524 15:16:47 InnoDB: highest supported file format is Barracuda.
        130524 15:16:47  InnoDB: Waiting for the background threads to start
        130524 15:16:48 InnoDB: 1.1.8 started; log sequence number 1595685
        130524 15:16:48 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
        130524 15:16:48 [Note]   - '127.0.0.1' resolves to '127.0.0.1';
        130524 15:16:48 [Note] Server socket created on IP: '127.0.0.1'.
        130524 15:16:48 [Note] Event Scheduler: Loaded 0 events
        130524 15:16:48 [Note] /www/wdlinux/mysql/bin/mysqld: ready for connections.
進(jìn)入phpmyadmin,顯示還是5.1版本。這是怎么回事?
這里的前面,明明說(shuō)了,先升級(jí)mysql,再升級(jí)php
怎么后面,就升級(jí)php,再升級(jí)mysql了?
什么邏輯?
回admin:是我翻論壇問(wèn)google大半天弄得頭昏腦漲,再加上年紀(jì)有點(diǎn)大,寫錯(cuò)了。應(yīng)該是“先升級(jí)php后升級(jí)mysql”。其實(shí)你要是有耐心看看就明白是個(gè)筆誤了。是這個(gè)帖子http://www.gps-cemuyi.cn/bbs/thread-3737-2-1.html里ngibo1278網(wǎng)友說(shuō)的:
發(fā)表于 2012-10-10 00:09 | 只看該作者
折騰了兩個(gè)夜晚,終于成功了,謝謝老大的耐心指導(dǎo)!
正確的升級(jí)流程是:先安裝WDCP面板,隨后安裝cmake,一定要安裝這個(gè)文件,隨后升級(jí)php,隨后升級(jí)相關(guān)的php緩存插件,隨后升級(jí)mysql,這樣才完全升級(jí)成功。之前出錯(cuò)可能是cmake文件的版本問(wèn)題,開始用的高版本,后來(lái)?yè)Q到低版本,再先升級(jí)php,這樣才行;先升級(jí)mysql,后面安裝php要調(diào)整很多地方。
不過(guò)你當(dāng)時(shí)也不太相信ngibo1278的方法:
回復(fù) 29# ngibo1278
升級(jí)腳本里有自動(dòng)安裝cmake的
按理,先升級(jí)mysql,再升級(jí)php會(huì)更好的,如果同時(shí)也要升級(jí)mysql的話
php調(diào)整很多地方,比如呢?
這幾天翻論壇的感覺(jué)有兩點(diǎn):
1、菜鳥太多,毫無(wú)疑問(wèn)我也是。其實(shí)這是肯定的,都是高手都能自己搞定上來(lái)問(wèn)個(gè)P啊,對(duì)吧?
2、admin的脾氣有點(diǎn)點(diǎn)大。當(dāng)然你是高手,瞧不起菜鳥是有資格的,對(duì)有些菜鳥不肯翻帖子我也有點(diǎn)看不過(guò)去。不過(guò)這個(gè)論壇不就是為了大家解決使用中碰到的問(wèn)題的嗎?
呵呵,今天喝了點(diǎn)小酒,有點(diǎn)直截了當(dāng),得罪得罪
哇靠!莫名其妙地好了。
下午在單位又是重啟web,又是重啟mysql,再是重啟整個(gè)服務(wù)器,折騰了不知多少次,phpmyadmin里面就是顯示mysql是5.1.63,剛剛頂撞了admin一下再翻帖子,才注意到wdcp后臺(tái)有獨(dú)立的apache,php。嘗試不通過(guò)wdcp而是直接連接到后臺(tái)phpmyadmin,里面竟然已經(jīng)顯示mysql 5.5.27了,再到wdcp里面去看也是5.5.27了。當(dāng)然肯定不是因?yàn)槲蚁戎苯拥卿浟藀hpmyadmin,反正現(xiàn)在好了。不過(guò)估計(jì)admin又要讓我去看簽名了哈哈
補(bǔ)充一下,以我的經(jīng)歷證明了ngibo1278說(shuō)的是對(duì)的,要升級(jí)的話一定要“先升級(jí)php再升級(jí)mysql”
我沒(méi)什么脾氣,也不敢說(shuō)是什么高手,也理解每一次新人,因?yàn)槲乙彩沁@樣過(guò)來(lái)的
不過(guò)我確實(shí)沒(méi)有耐心,也看不慣一些,教程,文檔,FAQ都不看,就說(shuō)這說(shuō)那的人
對(duì)于這個(gè)問(wèn)題,我還是堅(jiān)持我認(rèn)為正確的操作方法是,先mysql,后php
當(dāng)然,只要能正常,這個(gè)順序也不是必須
后來(lái)仔細(xì)想想,這個(gè)問(wèn)題不一定是wdcp或者服務(wù)器哪里有什么不對(duì),最可能的原因是我的瀏覽器緩存,我只是刷新了頁(yè)面,沒(méi)有清空重來(lái)。
