[求助] 請(qǐng)問(wèn)WDCP3.2.21如何設(shè)置Nginx支持TP5的pathinfo?
我在網(wǎng)上找了一些方法修改對(duì)應(yīng)域名的.conf但是沒(méi)有辦法完成 請(qǐng)問(wèn)如何可以實(shí)現(xiàn)呢?
求大神們幫幫解決。!
同求同求,現(xiàn)在的配置文件是錯(cuò)的,獲取不到PATHINFO
我找到了一種辦法,配置文件如下:
server {
        listen       80;
        root /www/web/xxxx/public_html;
        include /www/wdlinux/wdcp/rewrite/robelf_nginx.conf;
        server_name xxxx.com www.xxxx.com;
        index  index.html index.php index.htm;
        error_page  400 /errpage/400.html;
        error_page  403 /errpage/403.html;
        error_page  404 /errpage/404.html;
        error_page  503 /errpage/503.html;
        location ~ \.php {
                fastcgi_pass  unix:/tmp/php-56-cgi.sock;
                fastcgi_index  index.php;
                include fcgi.conf;
                set $real_script_name $fastcgi_script_name;
                if ($fastcgi_script_name ~ "^(.+?\.php)(/.+)$") {
                        set $real_script_name $1;
                        set $path_info $2;
                fastcgi_param SCRIPT_FILENAME $document_root$real_script_name;
                fastcgi_param SCRIPT_NAME $real_script_name;
                fastcgi_param PATH_INFO $path_info;
        location ~ /\.ht {
                deny  all;
        location / {
                 try_files $uri $uri/ /?$args;
回復(fù) 4# hyqlhy
    感謝,我先嘗試一下!
安裝完成需要配置Nginx相關(guān)文件重新啟動(dòng)服務(wù)器即可的
這個(gè)人很勤快~暫時(shí)沒(méi)有個(gè)性簽名
回復(fù) 6# Miker
    你這當(dāng)什么都沒(méi)說(shuō)啊
回復(fù) 1# Locked
    你好,打開(kāi)wdcp面板,找到-文件管理-點(diǎn)擊nginx,然后修改對(duì)應(yīng)站點(diǎn)的nginx配置為:
  1.    location ~ \.php(.*)$ {
  2.                 fastcgi_pass  unix:/tmp/php-56-cgi.sock;
  3.                 fastcgi_index  index.php;
  4.                 fastcgi_param  SCRIPT_FILENAME  $DOCUMENT_ROOT$fastcgi_script_name;
  5.               fastcgi_param PATH_INFO $2;
  6. include fcgi.conf;
  7. set $path_info "";
  8. set $real_script_name $fastcgi_script_name;
  9. if ($fastcgi_script_name ~ "^(.+\.php)(/.+)$") {
  10. set $real_script_name $1;
  11. set $path_info $2;
  12. }
  13. fastcgi_param SCRIPT_NAME $real_script_name;
  14. fastcgi_param PATH_INFO $path_info;
  15.         }
回復(fù) 8# jiangyouhong
    當(dāng)然了,要從啟一下web服務(wù)
/www/wdlinux/wdcp/rewrite/robelf_nginx.conf; 這個(gè)文件呢?
