[分享] APC 3.1.13 安裝教程
  1. wget http://pecl.php.net/get/APC-3.1.13.tgz
  2. tar xvzf APC-3.1.13.tgz
  3. cd APC-3.1.13
  4. /www/wdlinux/php/bin/phpize
  5. ./configure –enable-apc –enable-apc-mmap –with-php-config=/www/wdlinux/php/bin/php-config
  6. make
  7. make install
編譯后確保www/wdlinux/php/lib/php/extensions/no-debug-non-zts-20090626/路徑下有apc.so
在php.ini后添加
  1. [apc]
  2. extension_dir="/www/wdlinux/php/lib/php/extensions/no-debug-non-zts-20090626/"
  3. extension="apc.so"
  4. apc.enabled = 1
  5. apc.cache_by_default = on
  6. apc.shm_segments = 1
  7. apc.shm_size = 128
  8. apc.ttl = 7200
  9. apc.user_ttl = 7200
  10. apc.mmap_file_mask=/tmp/apc.XXXXXX
  11. apc.num_files_hint = 0
  12. apc.write_lock = On
我的試驗(yàn)成功,分享下,如果其他人成功就好,不成功誤怪
這個(gè)方法安裝不上呢 我的wdcp最新版 php5.2
  1. [root@wdOS ~]# cd APC-3.1.13
  2. [root@wdOS APC-3.1.13]# /www/wdlinux/apache_php-5.2.17/bin/phpize
  3. Configuring for:
  4. PHP Api Version:         20041225
  5. Zend Module Api No:      20060613
  6. Zend Extension Api No:   220060519
  7. [root@wdOS APC-3.1.13]# ./configure ?enable-apc ?enable-apc-mmap ?with-php-config=/www/wdlinux/apache_php-5.2.17/bin/php-config
  8. configure: WARNING: you should use --build, --host, --target
  9. configure: WARNING: invalid host type: ?enable-apc
  10. configure: WARNING: you should use --build, --host, --target
  11. configure: WARNING: invalid host type: ?enable-apc-mmap
  12. configure: error: invalid variable name: ?with-php-config
  13. [root@wdOS APC-3.1.13]# make
  14. make: *** No targets specified and no makefile found.  Stop.
  15. [root@wdOS APC-3.1.13]# make install
  16. make: *** No rule to make target `install'.  Stop.
回復(fù) 3# lfq1989
  1. ./configure –enable-apc –enable-apc-mmap –with-php-config=/www/wdlinux/php/bin/php-config
這行代碼需要你手動(dòng)輸入,直接復(fù)制粘貼就會(huì)出現(xiàn)這種錯(cuò)誤……
