[求助] 老大啊,怎么安裝gettext,一直出錯(cuò)
[root@289930 gettext]# ./configure -with-php-config=/www/wdlinux/php-5.2.17/bin/php-config with-gettext
configure: WARNING: you should use --build, --host, --target
checking for egrep... grep -E
checking for with-gettext-cc... no
checking for with-gettext-gcc... no
checking for cc... cc
checking for cc option to accept ANSI C... none needed
checking for icc... no
checking for suncc... no
checking build system type... Invalid configuration `with-gettext': machine `with' not recognized
configure: error: /bin/sh ./config.sub with-gettext failed
[root@289930 gettext]# //./configure -with-php-config=/www/wdlinux/php-5.2.17/bin/php-config with-gettext
-bash: //./configure: No such file or directory
這個(gè)怎么解決哇
百度了n久沒(méi)結(jié)果,http://blog.coverer.net/tag/wdcp 看這個(gè)教程做的
./configure --with-php-config=/www/wdlinux/php-5.2.17/bin/php-config --with-gettext
