[BUG反饋] centos5.6 32位wdcp_v2.4RPM包LNMP 創(chuàng)建站點(diǎn)成功,上傳程序出現(xiàn)502 Bad Gateway
本帖最后由 zhanjun 于 2012-7-15 20:18 編輯
wdcp_v2.4創(chuàng)建站點(diǎn)成功,域名打開是官方默認(rèn)的創(chuàng)建站長成功html界面,但是我自己上傳程序上去打開訪問卻是502 Bad Gateway,無法安裝網(wǎng)站程序,求解決測試頁面http://test.znsmw.com/
用的nginx web,沒有選擇偽靜態(tài)
剛才試了一下,在系統(tǒng)設(shè)置--web引擎切換--選擇了
1 apache    表示apache+php+mysql
3 nginx+apache 表示nginx+apache+php+mysql的組合
都可以訪問,
但是就是
2 nginx     表示nginx+php+mysql出現(xiàn)502 Bad Gateway
求解釋
wdlinux.cn
1 對應(yīng)版塊,提供系統(tǒng)版本位數(shù),wdcp版本,lamp,lnmp,lnamp是哪個(gè)環(huán)境,rpm或編譯安裝
VPS 1G  雙核
安裝的是 lanmp_wdcp_v2.4快速安裝RPM包
只能使用
web引擎
web引擎
2
nginx     表示nginx+php+mysql 訪問就會 出現(xiàn)502 Bad Gateway
wdlinux.cn
在SSH連接登錄后
service nginxd restart
看看
回復(fù) 4# admin
[root@centos ~]# service nginxd restart
Stopping nginx: nginx: [warn] conflicting server name "123.znsmw.com" on 0.0.0.0:80, ignored
nginx: [error] open() "/www/wdlinux/nginx-1.0.15/logs/nginx.pid" failed (2: No such file or directory)
                                                           [  OK  ]
Shutting down php_fpm warning, no pid file found - php-fpm is not running ?
Starting nginx: nginx: [warn] conflicting server name "123.znsmw.com" on 0.0.0.0:80, ignored
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
                                                           [FAILED]
Starting php_fpm Error in argument 1, char 1: no argument for option -
Usage: php-cgi [-q] [-h] [-s] [-v] [-i] [-f <file>]
       php-cgi <file> [args...]
  -a               Run interactively
  -b <address:port>|<port> Bind Path for external FASTCGI Server mode
  -C               Do not chdir to the script's directory
  -c <path>|<file> Look for php.ini file in this directory
  -n               No php.ini file will be used
  -d foo[=bar]     Define INI entry foo with value 'bar'
  -e               Generate extended information for debugger/profiler
  -f <file>        Parse <file>.  Implies `-q'
  -h               This help
  -i               PHP information
  -l               Syntax check only (lint)
  -m               Show compiled in modules
  -q               Quiet-mode.  Suppress HTTP Header output.
  -s               Display colour syntax highlighted source.
  -v               Version number
  -w               Display source with stripped comments and whitespace.
  -z <file>        Load Zend extension <file>.
  -T <count>       Measure execution time of script repeated <count> times.
................................... failed
重啟nginx失敗,VPS重啟了好幾次還是不行
wdlinux.cn
本帖最后由 huzs1622 于 2012-9-1 16:39 編輯
我的也出這問題,在APACHE作為web服務(wù)器的時(shí)候,php是正常的。切換到NGINX后,php就無法運(yùn)行了。
huzs.net
