[BUG反饋] WDCP服務(wù)癱瘓了
本帖最后由 luoblo 于 2012-9-11 09:04 編輯
因?yàn)闇y試smtp 發(fā)信,在wdcp后臺(tái),關(guān)閉啟動(dòng)selinux,后來又在后臺(tái)重啟服務(wù)器。
重啟動(dòng)后 建立的網(wǎng)站不能訪問,8080端口后臺(tái)也不能訪問。
httpd mysql 服務(wù)手動(dòng)start后,頁面有顯示,但是后臺(tái)沒有,虛擬網(wǎng)站好像都丟失了。
全部的虛擬主機(jī)反問是顯示一下頁面。8080后臺(tái)找不到服務(wù)。這個(gè)是第2次上次也這樣重裝了系統(tǒng)和后臺(tái)。centos5.6 +lamp   wdcp升級(jí)的最新版本。
Apache 2 Test Page
[size=-1]powered by CentOS
This page is used to test the proper operation of the Apache HTTP server after it has been installed. If you can read this page it means that the Apache HTTP server installed at this site is working properly.
If you are a member of the general public:
The fact that you are seeing this page indicates that the website you just visited is either experiencing problems or is undergoing routine maintenance.
If you would like to let the administrators of this website know that you've seen this page instead of the page you expected, you should send them e-mail. In general, mail sent to the name "webmaster" and directed to the website's domain should reach the appropriate person.
For example, if you experienced problems while visiting www.example.com, you should send e-mail to "webmaster@example.com".
If you are the website administrator:
You may now add content to the directory /var/www/html/. Note that until you do so, people visiting your website will see this page and not your content. To prevent this page from ever being used, follow the instructions in the file /etc/httpd/conf.d/welcome.conf.
You are free to use the images below on Apache and CentOS Linux powered HTTP servers. Thanks for using Apache and CentOS!
把selinux關(guān)掉再重起就可以
