[求助] eAccelerator0.9.6.1支持php5.4.26嗎?我怎么安裝失敗
eAccelerator0.9.6.1支持php5.4.26嗎?我怎么安裝失敗,求大神指教
eaccelerator-0.9.6.1/
eaccelerator-0.9.6.1/COPYING
eaccelerator-0.9.6.1/mm.h
eaccelerator-0.9.6.1/control.php
eaccelerator-0.9.6.1/AUTHORS
eaccelerator-0.9.6.1/doc/
eaccelerator-0.9.6.1/doc/php/
eaccelerator-0.9.6.1/doc/php/dasm.php
eaccelerator-0.9.6.1/doc/php/info.php
eaccelerator-0.9.6.1/doc/phpdoc.ini
eaccelerator-0.9.6.1/eaccelerator.c
eaccelerator-0.9.6.1/config.w32
eaccelerator-0.9.6.1/opcodes.c
eaccelerator-0.9.6.1/dasm.php
eaccelerator-0.9.6.1/eaccelerator.h
eaccelerator-0.9.6.1/ea_dasm.c
eaccelerator-0.9.6.1/NEWS
eaccelerator-0.9.6.1/mm.c
eaccelerator-0.9.6.1/ea_store.c
eaccelerator-0.9.6.1/eaccelerator.ini
eaccelerator-0.9.6.1/config.m4
eaccelerator-0.9.6.1/ea_restore.c
eaccelerator-0.9.6.1/debug.h
eaccelerator-0.9.6.1/bugreport.php
eaccelerator-0.9.6.1/ea_dasm.h
eaccelerator-0.9.6.1/README.win32
eaccelerator-0.9.6.1/opcodes.h
eaccelerator-0.9.6.1/ea_store.h
eaccelerator-0.9.6.1/ChangeLog
eaccelerator-0.9.6.1/fnmatch.h
eaccelerator-0.9.6.1/eaccelerator_version.h
eaccelerator-0.9.6.1/fnmatch.c
eaccelerator-0.9.6.1/Makefile.in
eaccelerator-0.9.6.1/ea_info.h
eaccelerator-0.9.6.1/.gitignore
eaccelerator-0.9.6.1/optimize.c
eaccelerator-0.9.6.1/debug.c
eaccelerator-0.9.6.1/PHP_Highlight.php
eaccelerator-0.9.6.1/ea_info.c
eaccelerator-0.9.6.1/win32/
eaccelerator-0.9.6.1/win32/eAccelerator.sln
eaccelerator-0.9.6.1/win32/eAccelerator.dsp
eaccelerator-0.9.6.1/win32/eAccelerator.vcproj
eaccelerator-0.9.6.1/win32/eAccelerator.dsw
eaccelerator-0.9.6.1/ea_restore.h
make: *** 沒有規(guī)則可以創(chuàng)建目標(biāo)“clean”。 停止。
Configuring for:
PHP Api Version:         20100412
Zend Module Api No:      20100525
Zend Extension Api No:   220100525
configure: WARNING: unrecognized options: --with-eaccelerator-shared-memory
checking for cc... cc
checking for icc... no
checking for suncc... no
checking for PHP prefix... /www/wdlinux/nginx_php-5.4.26
checking for PHP includes... -I/www/wdlinux/nginx_php-5.4.26/include/php -I/www/wdlinux/nginx_php-5.4.26/include/php/main -I/www/wdlinux/nginx_php-5.4.26/include/php/TSRM -I/www/wdlinux/nginx_php-5.4.26/include/php/Zend -I/www/wdlinux/nginx_php-5.4.26/include/php/ext -I/www/wdlinux/nginx_php-5.4.26/include/php/ext/date/lib
checking for PHP extension directory... /www/wdlinux/nginx_php-5.4.26/lib/php/extensions/no-debug-non-zts-20100525
checking for PHP installed headers prefix... /www/wdlinux/nginx_php-5.4.26/include/php
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking whether to enable eaccelerator support... yes, shared
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for unistd.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking mandatory system headers... yes
checking whether union semun is defined in sys/sem.h... no
checking for sysvipc shared memory support... yes
checking for mmap shared memory support... yes
checking for mmap on /dev/zero shared memory support... yes
checking for anonymous mmap shared memory support... yes
checking for posix mmap shared memory support... no
checking for best shared memory type... sysvipc
checking for spinlock semaphores support... yes
checking for pthread semaphores support... yes
checking for posix semaphores support... no
checking for sysvipc semaphores support... yes
checking for fcntl semaphores support... yes
checking for flock semaphores support... yes
checking for best semaphores type... spinlock
checking for mprotect... yes
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking how to recognize dependent libraries... pass_all
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 1966080
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... no
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking how to hardcode library paths into programs... immediate
checking whether to build shared libraries... yes
checking whether to build static libraries... no
creating libtool
config.status: creating config.h
/bin/sh /tmp/2/eaccelerator-0.9.6.1/libtool --mode=compile cc  -I. -I/tmp/2/eaccelerator-0.9.6.1 -DPHP_ATOM_INC -I/tmp/2/eaccelerator-0.9.6.1/include -I/tmp/2/eaccelerator-0.9.6.1/main -I/tmp/2/eaccelerator-0.9.6.1 -I/www/wdlinux/nginx_php-5.4.26/include/php -I/www/wdlinux/nginx_php-5.4.26/include/php/main -I/www/wdlinux/nginx_php-5.4.26/include/php/TSRM -I/www/wdlinux/nginx_php-5.4.26/include/php/Zend -I/www/wdlinux/nginx_php-5.4.26/include/php/ext -I/www/wdlinux/nginx_php-5.4.26/include/php/ext/date/lib  -DHAVE_CONFIG_H  -g -O2   -c /tmp/2/eaccelerator-0.9.6.1/eaccelerator.c -o eaccelerator.lo
mkdir .libs
cc -I. -I/tmp/2/eaccelerator-0.9.6.1 -DPHP_ATOM_INC -I/tmp/2/eaccelerator-0.9.6.1/include -I/tmp/2/eaccelerator-0.9.6.1/main -I/tmp/2/eaccelerator-0.9.6.1 -I/www/wdlinux/nginx_php-5.4.26/include/php -I/www/wdlinux/nginx_php-5.4.26/include/php/main -I/www/wdlinux/nginx_php-5.4.26/include/php/TSRM -I/www/wdlinux/nginx_php-5.4.26/include/php/Zend -I/www/wdlinux/nginx_php-5.4.26/include/php/ext -I/www/wdlinux/nginx_php-5.4.26/include/php/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/2/eaccelerator-0.9.6.1/eaccelerator.c  -fPIC -DPIC -o .libs/eaccelerator.o
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c: 在函數(shù)‘eaccelerator_restore’中:
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c:878: 警告:賦值丟棄了指針目標(biāo)類型的限定
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c: 在函數(shù)‘eaccelerator_compile_file’中:
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c:1317: 錯(cuò)誤:‘zend_class_entry’沒有名為‘line_start’的成員
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c: 在文件層:
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c:1913: 錯(cuò)誤:expected ‘=’, ‘,’, ‘;’, ‘a(chǎn)sm’ or ‘__attribute__’ before ‘eaccelerator_functions’
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c:1938: 錯(cuò)誤:‘eaccelerator_functions’未聲明(不在函數(shù)內(nèi))
make: *** [eaccelerator.lo] 錯(cuò)誤 1
make err
新劇場(chǎng)
我也是一樣的問題。。。
