[已解決] 在centos 5.3中安裝的2.0提示如下信息,在線等
本帖最后由 cngzit 于 2012-10-20 13:28 編輯
checking for statvfs... yes
checking for std_syslog... no
checking for strcasecmp... yes
checking for strcoll... yes
checking for strdup... yes
checking for strerror... yes
checking for strftime... yes
checking for strnlen... yes
checking for strptime... yes
checking for strstr... yes
checking for strtok_r... yes
checking for symlink... yes
checking for tempnam... yes
checking for tzset... yes
checking for unlockpt... yes
checking for unsetenv... yes
checking for usleep... yes
checking for utime... yes
checking for vsnprintf... yes
checking for nanosleep... checking for nanosleep in -lrt... yes
yes
checking for getaddrinfo... yes
checking for strlcat... no
checking for strlcpy... no
checking for getopt... yes
checking whether utime accepts a null argument... yes
checking for working alloca.h... (cached) yes
checking for alloca... yes
checking for declared timezone... yes
checking for type of reentrant time-related functions... POSIX
checking for readdir_r... yes
checking for type of readdir_r... POSIX
checking for in_addr_t... yes
checking for crypt_r... no
General settings
checking whether to include gcov symbols... no
checking whether to include debugging symbols... no
checking layout of installed files... PHP
checking path to configuration file... /www/wdlinux/etc
checking where to scan for configuration files...
checking whether to enable safe mode by default... no
checking for safe mode exec dir... /usr/local/php/bin
checking whether to enable PHP's own SIGCHLD handler... no
checking whether to enable magic quotes by default... no
checking whether to explicitly link against libgcc... no
checking whether to enable short tags by default... yes
checking whether to enable dmalloc... no
checking whether to enable IPv6 support... yes
checking how big to make fd sets... using system default
Configuring extensions
checking size of long... (cached) 4
checking for int32_t... yes
checking for uint32_t... yes
checking for strtoll... yes
checking for atoll... yes
checking for strftime... (cached) yes
checking whether to enable LIBXML support... yes
checking libxml2 install dir... /usr
checking for xml2-config path... /usr/bin/xml2-config
checking whether libxml build works... yes
checking for OpenSSL support... yes
checking for Kerberos support... no
checking for DSA_get_default_method in -lssl... yes
checking for pkg-config... /usr/bin/pkg-config
checking for PCRE support... yes
checking for ZLIB support... yes
checking if the location of ZLIB install directory is defined... no
checking for gzgets in -lz... yes
checking whether to enable bc style precision math functions... no
checking for BZip2 support... no
checking whether to enable calendar conversion support... no
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking if we should use cURL for url streams... no
checking for cURL in default path... found in /usr
checking for cURL 7.10.5 or greater... libcurl 7.15.5
checking for SSL support in libcurl... yes
checking how to run the C preprocessor... gcc -E
checking for openssl support in libcurl... yes
checking for openssl/crypto.h... yes
checking for gnutls support in libcurl... no
checking for curl_easy_perform in -lcurl... yes
checking for curl_version_info in -lcurl... yes
checking for curl_easy_strerror in -lcurl... yes
checking for curl_multi_strerror in -lcurl... yes
checking for QDBM support... no
checking for GDBM support... no
checking for NDBM support... no
checking for Berkeley DB4 support... no
checking for Berkeley DB3 support... no
checking for Berkeley DB2 support... no
checking for DB1 support... no
checking for DBM support... no
checking for CDB support... no
checking for INI File support... no
checking for FlatFile support... no
checking whether to enable DBA interface... no
checking whether to enable dbase support... no
checking whether to enable DOM support... yes
checking for xml2-config path... (cached) /usr/bin/xml2-config
checking whether libxml build works... (cached) yes
checking whether to enable EXIF (metadata from images) support... no
checking for FrontBase SQL92 (fbsql) support... no
checking for FDF support... no
checking whether to enable input filter support... yes
checking pcre install prefix... no
checking whether to enable FTP support... yes
checking OpenSSL dir for FTP... no
checking for GD support... yes
checking for the location of libjpeg... yes
checking for the location of libpng... yes
checking for the location of libXpm... no
checking for FreeType 1.x support... no
checking for FreeType 2... yes
checking for T1lib support... no
checking whether to enable truetype string function in GD... yes
checking whether to enable JIS-mapped Japanese font support in GD... no
checking for fabsf... yes
checking for floorf... yes
configure: error: libjpeg.(a|so) not found.
----Install Error: php configure err -----------
錯誤解決可參考:
http://www.gps-cemuyi.cn/bbs/thread-3855-1-1.html
個人
從這里往回看呢
菜鳥不懂
yum install libjpeg.(a|so)
本人是菜鳥
個人
yum install libjpeg.a
yum install libjpeg.so  ?
嘗試一下,我也菜鳥,多嘗試就明白了
[root@jxhcx ~]# yum install libjpeg.a
Loaded plugins: fastestmirror
* extras: mirrors.163.com
* rpmforge: mirror.oscc.org.my
* base: mirrors.163.com
* updates: mirrors.163.com
Setting up Install Process
Parsing package install arguments
No package libjpeg.a available.
Nothing to do
個人
證明沒這個包
試試這個
yum install -y libjpeg-devel
你看看把admin搞出來了
求官方QQ群
回復(fù) 8# admin
現(xiàn)在出現(xiàn)以下提示:
checking for openssl support in libcurl... no
checking for curl_easy_perform in -lcurl... no
configure: error: There is something wrong. Please check config.log for more information.
----Install Error: wdphp configure err -----------
個人
這樣看不出問題
看下config.log這個文件的最后臺是什么問題
