[求助] wdcp后臺(tái)打不開(kāi)。
wdcp后臺(tái)打不開(kāi),修改過(guò)端口。
vi /www/wdlinux/wdapache/conf/httpd.conf  打開(kāi)不對(duì)。
  1. login as: root
  2. root@182.92.0.0's password:
  3. Last login: Mon Apr 11 20:22:35 2016 from 222.220.0.0
  4. Welcome to aliyun Elastic Compute Service!
  5. [root@AY140718164752454eefZ ~]# vi /www/wdlinux/wdapache/conf/httpd.conf
  6. E325: ATTENTION
  7. Found a swap file by the name "/www/wdlinux/wdapache/conf/.httpd.conf.swp"
  8.           owned by: root   dated: Mon Apr 11 19:10:20 2016
  9.          file name: /www/wdlinux/wdapache/conf/httpd.conf
  10.           modified: YES
  11.          user name: root   host name: AY140718164xxxx4eefZ
  12.         process ID: 18138
  13. While opening file "/www/wdlinux/wdapache/conf/httpd.conf"
  14.              dated: Fri Apr  1 00:04:43 2016
  15. (1) Another program may be editing the same file.
  16.     If this is the case, be careful not to end up with two
  17.     different instances of the same file when making changes.
  18.     Quit, or continue with caution.
  19. (2) An edit session for this file crashed.
  20.     If this is the case, use ":recover" or "vim -r /www/wdlinux/wdapache/conf/ht
  21. tpd.conf"
  22.     to recover the changes (see ":help recovery").
  23.     If you did this already, delete the swap file "/www/wdlinux/wdapache/conf/.h
  24. ttpd.conf.swp"
  25.     to avoid this message.
  26. -- More --
其他功能正常,就是打不開(kāi)后臺(tái)。
