[求助] 安裝的時候出這種問題。
/root/src/mysql-5.6.30/sql/sql_planner.cc: In member function 'void Optimize_table_order::best_access_path(JOIN_TAB*, table_map, uint, bool, double, POSITION*, POSITION*)':
/root/src/mysql-5.6.30/sql/sql_planner.cc:335:52: warning: 'loose_scan_opt.Loose_scan_opt::best_max_loose_keypart' may be used uninitialized in this function [-Wmaybe-uninitialized]
       pos->loosescan_parts= best_max_loose_keypart + 1;
/root/src/mysql-5.6.30/sql/sql_planner.cc:431:18: note: 'loose_scan_opt.Loose_scan_opt::best_max_loose_keypart' was declared here
   Loose_scan_opt loose_scan_opt;
/root/src/mysql-5.6.30/sql/sql_planner.cc:333:54: warning: 'loose_scan_opt.Loose_scan_opt::best_loose_scan_start_key' may be used uninitialized in this function [-Wmaybe-uninitialized]
       pos->key=             best_loose_scan_start_key;
/root/src/mysql-5.6.30/sql/sql_planner.cc:431:18: note: 'loose_scan_opt.Loose_scan_opt::best_loose_scan_start_key' was declared here
/root/src/mysql-5.6.30/sql/sql_planner.cc:332:52: warning: 'loose_scan_opt.Loose_scan_opt::best_loose_scan_records' may be used uninitialized in this function [-Wmaybe-uninitialized]
       pos->records_read=    best_loose_scan_records;
/root/src/mysql-5.6.30/sql/sql_planner.cc:431:18: note: 'loose_scan_opt.Loose_scan_opt::best_loose_scan_records' was declared here
/root/src/mysql-5.6.30/sql/sql_planner.cc:334:48: warning: 'loose_scan_opt.Loose_scan_opt::best_loose_scan_key' may be used uninitialized in this function [-Wmaybe-uninitialized]
       pos->loosescan_key=   best_loose_scan_key;
/root/src/mysql-5.6.30/sql/sql_planner.cc:431:18: note: 'loose_scan_opt.Loose_scan_opt::best_loose_scan_key' was declared here
