[求助] 在安裝PDO_MYSQL 的時候提示錯誤,跪求前輩幫幫忙 re2c 0.13.4?
Configuring for:
PHP Api Version:         20041225
Zend Module Api No:      20060613
Zend Extension Api No:   220060519
config.m4:135: warning: AC_CACHE_VAL(pdo_inc_path, ...): suspicious cache-id, must contain _cv_ to be cached
../../lib/autoconf/general.m4:1974: AC_CACHE_VAL is expanded from...
../../lib/autoconf/general.m4:1994: AC_CACHE_CHECK is expanded from...
aclocal.m4:2741: PHP_CHECK_PDO_INCLUDES is expanded from...
config.m4:135: the top level
checking for cc... cc
checking for icc... no
checking for suncc... no
checking for PHP prefix... /www/wdlinux/apache_php-5.2.17
checking for PHP includes... -I/www/wdlinux/apache_php-5.2.17/include/php -I/www/wdlinux/apache_php-5.2.17/include/php/main -I/www/wdlinux/apache_php-5.2.17/include/php/TSRM -I/www/wdlinux/apache_php-5.2.17/include/php/Zend -I/www/wdlinux/apache_php-5.2.17/include/php/ext -I/www/wdlinux/apache_php-5.2.17/include/php/ext/date/lib
checking for PHP extension directory... /www/wdlinux/apache_php-5.2.17/lib/php/extensions/no-debug-non-zts-20060613
checking for PHP installed headers prefix... /www/wdlinux/apache_php-5.2.17/include/php
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking for MySQL support for PDO... yes, shared
checking for the location of libz... no
checking for mysql_config... not found
configure: error: Cannot find MySQL header files under
太菜鳥了,什么re2c 0.13.4的 應該怎么解決 跪求幫忙  謝謝
NIIIG.COM
