[BUG反饋] 錯誤提示:wdcp.service failed because
全部安裝完畢后提示:
  1. Starting wdcp (via systemctl):  Job for wdcp.service failed because the control process exited with error code. See "systemctl status wdcp.service" and "journalctl -xe" for details.
  2.                                                            [FAILED]
復制代碼
wdcp.service內容:
  1. ● wdcp.service - SYSV: wdCP system
  2.    Loaded: loaded (/etc/rc.d/init.d/wdcp; bad; vendor preset: disabled)
  3.    Active: failed (Result: exit-code) since Thu 1970-01-01 08:00:18 CST; 47 years 9 months ago
  4.      Docs: man:systemd-sysv-generator(8)
  5.   Process: 971 ExecStart=/etc/rc.d/init.d/wdcp start (code=exited, status=1/FAILURE)
  6. Jan 01 08:00:18 centos-rpi3 systemd[1]: Starting SYSV: wdCP system...
  7. Jan 01 08:00:18 centos-rpi3 wdcp[971]: /etc/rc.d/init.d/wdcp: line 15: /etc...ry
  8. Jan 01 08:00:18 centos-rpi3 systemd[1]: wdcp.service: control process exited...1
  9. Jan 01 08:00:18 centos-rpi3 systemd[1]: Failed to start SYSV: wdCP system.
  10. Jan 01 08:00:18 centos-rpi3 systemd[1]: Unit wdcp.service entered failed state.
  11. Jan 01 08:00:18 centos-rpi3 systemd[1]: wdcp.service failed.
  12. Hint: Some lines were ellipsized, use -l to show in full.
復制代碼
journalctl -xe 內容:
  1. Oct 21 02:25:42 centos-rpi3 polkitd[307]: Registered Authentication Agent for un
  2. Oct 21 02:25:42 centos-rpi3 systemd[1]: Reloading.
  3. Oct 21 02:25:42 centos-rpi3 polkitd[307]: Unregistered Authentication Agent for
  4. Oct 21 02:25:42 centos-rpi3 polkitd[307]: Registered Authentication Agent for un
  5. Oct 21 02:25:42 centos-rpi3 systemd[1]: Starting SYSV: wdCP system...
  6. -- Subject: Unit wdcp.service has begun start-up
  7. -- Defined-By: systemd
  8. -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
  9. --
  10. -- Unit wdcp.service has begun starting up.
  11. Oct 21 02:25:42 centos-rpi3 wdcp[1141]: /etc/rc.d/init.d/wdcp: line 15: /etc/sys
  12. Oct 21 02:25:43 centos-rpi3 systemd[1]: wdcp.service: control process exited, co
  13. Oct 21 02:25:43 centos-rpi3 systemd[1]: Failed to start SYSV: wdCP system.
  14. -- Subject: Unit wdcp.service has failed
  15. -- Defined-By: systemd
  16. -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
  17. --
  18. -- Unit wdcp.service has failed.
  19. --
  20. -- The result is failed.
  21. Oct 21 02:25:43 centos-rpi3 systemd[1]: Unit wdcp.service entered failed state.
  22. Oct 21 02:25:43 centos-rpi3 systemd[1]: wdcp.service failed.
  23. Oct 21 02:25:43 centos-rpi3 polkitd[307]: Unregistered Authentication Agent for
  24. lines 1543-1565/1565 (END)
復制代碼
