在sh install.sh 的時(shí)候卡住不動(dòng),怎么回事啊老大
在sh install.sh 的時(shí)候卡住不動(dòng)   卸載重裝了好幾次都是這個(gè)原因 求解
本帖最后由 vanani 于 2013-10-23 14:15 編輯
Select Install
    1 apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    2 nginx + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    3 nginx + apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    4 install all service
    5 don't install is now
Please Input 1,2,3,4,5: 4
Select php version:
    1 php-5.2.17 (default)
    2 php-5.3.27
Please Input 1,2: 1
error: skipping http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.3-1.el5.rf.x86_64.rpm - transfer failed - Unknown or unexpected error
Retrieving http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.3-1.el5.rf.x86_64.rpm
Setting up Install Process
No package gcc available.
No package gcc-c++ available.
No package make available.
No package autoconf available.
No package libtool-ltdl-devel available.
No package gd-devel available.
No package freetype-devel available.
No package libxml2-devel available.
No package libjpeg-devel available.
No package libpng-devel available.
No package openssl-devel available.
No package curl-devel available.
No package patch available.
No package libmcrypt-devel available.
No package libmhash-devel available.
No package ncurses-devel available.
No package libcap-devel available.
No package sendmail available.
No package unzip available.
Nothing to do
23 Oct 14:08:27 ntpdate[2556]: the NTP socket is in use, exiting
installing mysql,this may take a few minutes,hold on plz...
configure in progress ...
Preparing...                ##################################################
rpmforge-release            ##################################################
Resolving Dependencies
--> Running transaction check
---> Package libmcrypt-devel.x86_64 0:2.5.7-1.2.el5.rf set to be updated
--> Processing Dependency: libmcrypt = 2.5.7-1.2.el5.rf for package: libmcrypt-devel
--> Processing Dependency: libmcrypt.so.4()(64bit) for package: libmcrypt-devel
---> Package mhash-devel.x86_64 0:0.9.9-1.el5.rf set to be updated
--> Processing Dependency: mhash = 0.9.9-1.el5.rf for package: mhash-devel
--> Processing Dependency: libmhash.so.2()(64bit) for package: mhash-devel
---> Package libmcrypt.x86_64 0:2.5.7-1.2.el5.rf set to be updated
---> Package mhash.x86_64 0:0.9.9-1.el5.rf set to be updated
Dependencies Resolved
Package               Arch         Version                Repository      Size
Installing:
libmcrypt-devel       x86_64       2.5.7-1.2.el5.rf       rpmforge       112 k
mhash-devel           x86_64       0.9.9-1.el5.rf         rpmforge        19 k
Installing for dependencies:
libmcrypt             x86_64       2.5.7-1.2.el5.rf       rpmforge       182 k
mhash                 x86_64       0.9.9-1.el5.rf         rpmforge       161 k
Transaction Summary
Install      4 Package(s)
Update       0 Package(s)
Remove       0 Package(s)
Total download size: 475 k
Downloading Packages:
Total                                            67 kB/s | 475 kB     00:07
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
  Installing     : mhash                                                    1/4
  Installing     : libmcrypt                                                2/4
  Installing     : mhash-devel                                              3/4
  Installing     : libmcrypt-devel                                          4/4
Installed:
  libmcrypt-devel.x86_64 0:2.5.7-1.2.el5.rf mhash-devel.x86_64 0:0.9.9-1.el5.rf
Dependency Installed:
  libmcrypt.x86_64 0:2.5.7-1.2.el5.rf       mhash.x86_64 0:0.9.9-1.el5.rf
Complete!
23 Oct 14:09:09 ntpdate[2937]: the NTP socket is in use, exiting
本帖最后由 bosir_it 于 2013-10-25 14:17 編輯
我也是遇到這個(gè)問題呀,錯(cuò)誤略過以后,看似裝好了,其實(shí)解釋不了php網(wǎng)頁。但可以解釋html網(wǎng)頁,請指示如何做呀?
很復(fù)雜的樣子...
卡在 make in progress...都兩小時(shí)了
h1i2.com
本帖最后由 dmcountry 于 2013-11-12 21:27 編輯
我也是遇到這個(gè)問題呀,錯(cuò)誤略過以后,看似裝好了,其實(shí)解釋不了php網(wǎng)頁。但可以解釋html網(wǎng)頁,請指示如何做 ...
bosir_it 發(fā)表于 2013-10-25 14:16
我的中間沒出什么錯(cuò),但是也是解釋不了php,文本文件可以打開。前面選的是php5.3
查看了日志,安裝php時(shí)是make error
問題終于解決了,呵呵。。。。
php不解釋網(wǎng)頁的原因是php沒有能正確安裝,make error的原因是內(nèi)存耗盡(512MB VPS基本上編譯不過)。在php.net上找到了解決方法,這里直接給出本安裝腳本里的修改方法:
打開/root/lib/php.sh 找到 ./configure這一行,然后添加一行 【--disable-fileinfo /】,添加之后直接重新運(yùn)行安裝命令sh install.sh,不用卸載以前的安裝,編譯通過后重啟vps。
https://a.youhuima.cc
我全部安裝完成了  但是咧現(xiàn)在IP:8080是能訪問的   可是我裝DZ的時(shí)候   ip/dz/install/install.php的時(shí)候   都是提示我下載  而不是打開頁面  我是本地安裝的
回復(fù) 1# admin
大哥。。我這邊sh install.sh這個(gè)就停在這里不動(dòng),怎么辦?
已經(jīng)等了很久都不動(dòng)
希望這個(gè)安裝包能支持軟件安裝目錄的選擇,不知道可不可以實(shí)現(xiàn)呢,對于第一塊硬盤只有10g的vps  這樣把軟件都安裝在系統(tǒng)盤 很容易就滿了
安裝在其它盤上即可以
今天首次使用linux一鍵安裝成功,并安裝Discuz!x3.1成功 DW5 FTP連接正常很方便,謝謝!!!!感謝!!!!!!
[root@AY1312202027259870c1Z ~]# sh install.sh
No package screen available.
Nothing to do
Cannot find 'screen' command,install without screen(default yes)?
(Yes/No):
回復(fù) 73# 518433@qq.com
    怎么解決/
一鍵安裝太好了,太好了
