[BUG反饋] 驗證訪問錯誤,請指教
開啟驗證訪問后,進入網(wǎng)站輸入用戶名和密碼,然后就出現(xiàn)了下面的文字
驗證訪問錯誤Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, you@example.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
下面是我.htaccess
  1. php_flag magic_quotes_gpc Off
  2. # 1.To use URL Alias you need to be running apache with mod_rewrite enabled.
  3. # 2. In your opencart directory rename htaccess.txt to .htaccess.
  4. # For any support issues please visit: http://www.opencart.com
  5. Options +FollowSymlinks
  6. # Prevent Directoy listing
  7. Options -Indexes
  8. # Prevent Direct Access to files
  9. <FilesMatch "\.(tpl|ini|log)">
  10. Order deny,allow
  11. Deny from all
  12. </FilesMatch>
  13. # SEO URL Settings
  14. RewriteEngine On
  15. # If your opencart installation does not run on the main web folder make sure you folder it does run in ie. / becomes /shop/
  16. RewriteBase /
  17. RewriteCond %{HTTP_HOST} !^www.erafactory.com$ [NC]
  18. RewriteRule ^(.*)$ http://www.erafactory.com/$1 [L,R=301]
  19. RewriteRule ^sitemap.xml$ index.php?route=feed/google_main_sitemap [L]
  20. RewriteRule ^sitemap-en.xml$ index.php?route=feed/google_sitemap [L]
  21. RewriteRule ^sitemap-cn.xml$ index.php?route=cn/feed/google_sitemap [L]
  22. RewriteCond %{REQUEST_FILENAME} !-f
  23. RewriteCond %{REQUEST_FILENAME} !-d
  24. RewriteCond %{REQUEST_URI} !.*\.(ico|gif|jpg|jpeg|png|js|css)
  25. RewriteRule ^([^?]*) index.php?_route_=$1 [L,QSA]
  26. ### Additional Settings that may need to be enabled for some servers
  27. ### Uncomment the commands by removing the # sign in front of it.
  28. ### If you get an "Internal Server Error 500" after enabling any of the following settings, restore the # as this means your host doesn't allow that.
  29. # 1. If your cart only allows you to add one item at a time, it is possible register_globals is on. This may work to disable it:
  30. # php_flag register_globals off
  31. # 2. If your cart has magic quotes enabled, This may work to disable it:
  32. # php_flag magic_quotes_gpc Off
  33. # 3. Set max upload file size. Most hosts will limit this and not allow it to be overridden but you can try
  34. # php_value upload_max_filesize 999M
  35. # 4. set max post size. uncomment this line if you have a lot of product options or are getting errors where forms are not saving all fields
  36. # php_value post_max_size 999M
  37. # 5. set max time script can take. uncomment this line if you have a lot of product options or are getting errors where forms are not saving all fields
  38. # php_value max_execution_time 200
  39. # 6. set max time for input to be recieved. Uncomment this line if you have a lot of product options or are getting errors where forms are not saving all fields
  40. # php_value max_input_time 200
  41. # 7. disable open_basedir limitations
  42. # php_admin_value open_basedir none
驗證訪問,不用.htaccess吧?
