[求助] ----Install Error: wdphp configure err -----------什么原因
Sorry, I cannot run apxs.  Possible reasons follow:
1. Perl is not installed
2. apxs was not found. Try to pass the path using --with-apxs2=/path/to/apxs
3. Apache was not built using --enable-so (the apxs usage page is displayed)
The output of /www/wdlinux/wdapache/bin/apxs follows:
/www/wdlinux/wdapache/bin/httpd: error while loading shared libraries: libiconv.so.2: cannot open shared object file: No such file or directory
apxs:Error: Sorry, no shared object support for Apache.
apxs:Error: available under your platform. Make sure.
apxs:Error: the Apache module mod_so is compiled into.
apxs:Error: your server binary `/www/wdlinux/wdapache/bin/httpd'..
configure: error: Aborting
重起一下再編譯
重啟后!重新安裝還是這個(gè)問題
shutdown -r now 立刻重啟(root用戶使用)
sh in.sh
1
g++: Internal error: Killed (program cc1plus)
Please submit a full bug report.
See <URL:http://bugzilla.redhat.com/bugzilla> for instructions.
make[3]: *** [sql_yacc.o] Error 1
make[3]: Leaving directory `/root/lanmp/mysql-5.1.56/sql'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/root/lanmp/mysql-5.1.56/sql'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/root/lanmp/mysql-5.1.56/sql'
make: *** [all-recursive] Error 1
----Install Error: mysql make err -----------
什么系統(tǒng),版本?
