標(biāo)題: [求助] Warning: require(./ThinkPHP/setup.php) 錯(cuò)誤,咋回事啊這是 [打印本頁]
作者: hutanlong    時(shí)間: 2014-7-22 15:20     標(biāo)題: Warning: require(./ThinkPHP/setup.php) 錯(cuò)誤,咋回事啊這是
Warning: require(./ThinkPHP/setup.php) [function.require]: failed to open stream: Permission denied in /www/web/deleb/public_html/install.php on line 10
Fatal error: require() [function.require]: Failed opening required './ThinkPHP/setup.php' (include_path='.:/www/wdlinux/apache_php-5.2.17/lib/php') in /www/web/deleb/public_html/install.php on line 10
用的是云服務(wù)器 。cenros64位系統(tǒng),請(qǐng)高手解決,謝謝
作者: zpinsist    時(shí)間: 2017-5-8 20:56
剛用這個(gè)。。我也出現(xiàn)這個(gè)問題了。。。
