標題: [求助] 全新安裝出錯 請問什么原因 [打印本頁]
作者: qazkkl    時間: 2012-3-5 22:44     標題: 全新安裝出錯 請問什么原因
make[1]: *** [httpd] Error 1
make[1]: Leaving directory `/root/lanmp/httpd-2.2.22'
make: *** [all-recursive] Error 1
----Install Error: apache make err -----------
作者: admin    時間: 2012-3-5 23:19
多看提問智慧,詳細描述問題,環(huán)境,版本,錯誤信息等,能更快得到回復和解答
為什么就看不到紅字的字嗎?
作者: qazkkl    時間: 2012-3-5 23:24
回復 2# admin
Centos 5.7
全新安裝lanmp v2.2.1,詳細按照官方教程安裝,最后一步出現(xiàn)下面的錯誤
作者: admin    時間: 2012-3-5 23:36
這樣看不出問題原因
作者: qazkkl    時間: 2012-3-5 23:58
回復 4# admin
Configuring extensions
checking size of long... (cached) 4
checking for int32_t... (cached) yes
checking for uint32_t... (cached) yes
checking for strtoll... (cached) yes
checking for atoll... (cached) yes
checking libxml2 install dir... no
checking for xml2-config path... (cached) /usr/local/bin/xml2-config
configure: error: xml2-config not found. Please check your libxml2 installation.
----Install Error: wdphp configure err -----------
作者: admin    時間: 2012-3-6 00:32
yum install -y libxml2-devel
作者: qazkkl    時間: 2012-3-6 00:40
回復 6# admin
[root@localhost ~]# yum install -y libxml2-devel
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
   libxml2.so.2: cannot open shared object file: No such file or directory
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.4.3 (#1, Sep 21 2011, 20:06:00)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-51)]
If you cannot solve this problem yourself, please go to
the yum faq at:
  http://wiki.linux.duke.edu/YumFaq
作者: admin    時間: 2012-3-6 08:51
怎么會有這樣的錯誤提示,你的系統(tǒng)操作過什么或升級過什么?
作者: guzuomuse    時間: 2012-5-16 03:46
我也出現(xiàn)同樣的錯誤,不知道你們怎么解決的我
Centos5.8 32位,郁悶的要死。。。。。。。。!
作者: guzuomuse    時間: 2012-5-16 11:30
解決辦法…………
http://www.gps-cemuyi.cn/bbs/thread-2152-1-1.html
