標(biāo)題: [求助] 這里可以討論技術(shù)問題嗎?沒有指定的客戶IP能訪問的了域名嗎 [打印本頁]
作者: e66478    時間: 2012-4-1 13:29     標(biāo)題: 這里可以討論技術(shù)問題嗎?沒有指定的客戶IP能訪問的了域名嗎
來至電信的IP指向電信的服務(wù)器 網(wǎng)通走網(wǎng)通的,那么沒有在acl.conf添加的IP那怎么訪問啊
是默認(rèn)走第一個cnc_acl.conf 還是要在設(shè)置一個才能訪問,因為全國這么多IP總會有漏掉的
我的name.conf 配置
key "rndc-key" {
        algorithm hmac-md5;
        secret "X+QmNL9kY4YMmPwE9YfqFA==";
controls {
        inet 127.0.0.1 port 953
                allow { 127.0.0.1; } keys { "rndc-key"; };
logging {
channel query_log {
file "/var/log/named.log" versions 3 size 20m;
severity info;
print-time yes;
print-category yes;
print-severity yes;
category queries {
query_log;
options{
directory "/usr/local/bind/etc";
pid-file "named.pid";
acl "dns-ip-list"{
          192.168.0.65;
          192.168.0.11;
include "/usr/local/bind/etc/cnc_acl.conf";
include "/usr/local/bind/etc/telecom_acl.conf";
include "/usr/local/bind/etc/edu_acl.conf";
include "/usr/local/bind/etc/view.conf";
作者: admin    時間: 2012-4-1 14:28
可以指定一個默認(rèn)值
