標(biāo)題: [求助] yum update出錯(cuò)提示 [打印本頁(yè)]
作者: freemansxh    時(shí)間: 2012-5-27 17:00     標(biāo)題: yum update出錯(cuò)提示
centos 6.2 32位
lnamp (已升級(jí)到最新版)
最近使用yum update升級(jí)時(shí)出錯(cuò)提示,請(qǐng)問(wèn)老大如何解決?另外一臺(tái)配置基本相同的vps使用yum是正常的
yum update
Loaded plugins: fastestmirror, refresh-packagekit, security
* base: ftp.iij.ad.jp
* epel: ftp.iij.ad.jp
* extras: ftp.iij.ad.jp
* rpmforge: ftp.riken.jp
* updates: ftp.iij.ad.jp
Setting up Update Process
Resolving Dependencies
--> Running transaction check
---> Package iftop.i686 0:0.17-1.el6.rf will be updated
---> Package iftop.i386 0:1.0-0.1.pre2.el5 will be an update
--> Processing Dependency: libpcap.so.0.9.4 for package: iftop-1.0-0.1.pre2.el5.i386
---> Package iotop.noarch 0:0.3.2-3.el6 will be updated
---> Package iotop.noarch 0:0.4.1-2.el5 will be an update
--> Processing Dependency: python(abi) = 2.4 for package: iotop-0.4.1-2.el5.noarch
---> Package pptpd.i686 0:1.3.4-2.el6 will be updated
---> Package pptpd.i386 0:1.3.4-2.fc6 will be an update
--> Processing Dependency: ppp = 2.4.4 for package: pptpd-1.3.4-2.fc6.i386
---> Package python-ethtool.i686 0:0.6-1.el6 will be updated
---> Package python-ethtool.i386 0:0.6-2.el5 will be an update
--> Processing Dependency: python(abi) = 2.4 for package: python-ethtool-0.6-2.el5.i386
--> Finished Dependency Resolution
Error: Package: pptpd-1.3.4-2.fc6.i386 (poptop-stable)
           Requires: ppp = 2.4.4
           Installed: ppp-2.4.5-5.el6.i686 (@base)
               ppp = 2.4.5-5.el6
           Available: ppp-2.4.4-14.1.fc6.i386 (poptop-stable)
               ppp = 2.4.4-14.1.fc6
Error: Package: iftop-1.0-0.1.pre2.el5.i386 (epel)
           Requires: libpcap.so.0.9.4
Error: Package: iotop-0.4.1-2.el5.noarch (epel)
           Requires: python(abi) = 2.4
           Installed: python-2.6.6-29.el6.i686 (@anaconda-CentOS-201112130233.i386/6.2)
               python(abi) = 2.6
           Available: python26-2.6.8-1.el5.i386 (epel)
               python(abi) = 2.6
Error: Package: python-ethtool-0.6-2.el5.i386 (epel)
               python(abi) = 2.6
               python(abi) = 2.6
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
作者: admin    時(shí)間: 2012-5-27 17:07
作者: freemansxh    時(shí)間: 2012-5-27 19:54
執(zhí)行過(guò)的,沒(méi)用
作者: admin    時(shí)間: 2012-5-28 08:57
你之前應(yīng)該有做過(guò)其它操作?
作者: itxx    時(shí)間: 2012-5-28 21:52
yum  clean all
yum update
