阿里云的VPS上安裝失敗
xy83918
2012-6-1 01:37
阿里云的VPS上安裝失敗
直接安裝sh in.sh時
useradd: user 'wdcpu' already exists
installing mysql...
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... no
checking how to create a ustar tar archive... gnutar
checking for style of include used by make... none
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/root/lanmp/mysql-5.1.61':
在網(wǎng)上搜了一下可能是少 gcc
結(jié)果yum install gcc時又有如下報錯
Error: Package: glibc-headers-2.12-1.47.el6_2.12.x86_64 (updates)
Requires: kernel-headers >= 2.2.1
You could try using --skip-broken to work around the problem
** Found 1 pre-existing rpmdb problem(s), 'yum check' output follows:
kernel-2.6.32-220.13.1.el6.x86_64 has missing requires of kernel-firmware >= ('0
', '2.6.32', '220.13.1.el6')
求助
2012-6-1 08:54
http://www.gps-cemuyi.cn/bbs/thread-2287-1-1.html
xy83918
2012-6-1 12:15
請修改文件vi /etc/yum.conf 將exclude=kernel*前加注釋即可解決
xy83918
2012-6-1 12:48
吞噬
2014-2-14 16:58
RPM 包安裝就沒有這個問題、我用編碼安裝也是這個問題、
RPM包安裝
sh lanmp_wdcp_ins.sh
就可以
卸載 (切記備份好數(shù)據(jù))
就可以
