[教程]
在虛擬機(jī)安裝完后,用IE打不開后臺
A 首先檢查本機(jī)與虛擬機(jī)的網(wǎng)絡(luò)通不通?可以通過ping來判斷,如ping 192.168.1.100(這個(gè)是安裝時(shí)設(shè)置的虛擬機(jī)IP地址,根據(jù)實(shí)際來定)
B 如果能ping通,但還是打不開,登錄虛擬機(jī)的終片,用netstat –lnpt檢查是否有80,8080端口
C 檢查本機(jī)有沒開防火墻等
guxin0123
能ping通
能ssh
netstat –lnpt 沒有80 和8080端口
這個(gè)就不知道該怎么辦了
http://www.gps-cemuyi.cn/bbs/thread-192-1-1.html
看下是不是服務(wù)沒啟動
或手工啟動
guxin0123
我下的那個(gè)X86的 自動安裝手動安裝都試過了
服務(wù)列表里面沒有這幾個(gè)服務(wù) chkconfig --list
[root@wdOS var]# chkconfig --list
acpid 0:off 1:off 2:on 3:on 4:on 5:on 6:off
atd 0:off 1:off 2:off 3:on 4:on 5:on 6:off
cpuspeed 0:off 1:on 2:on 3:on 4:on 5:on 6:off
crond 0:off 1:off 2:on 3:on 4:on 5:on 6:off
gpm 0:off 1:off 2:off 3:off 4:off 5:off 6:off
haldaemon 0:off 1:off 2:off 3:off 4:off 5:off 6:off
iptables 0:off 1:off 2:on 3:on 4:on 5:on 6:off
irqbalance 0:off 1:off 2:on 3:on 4:on 5:on 6:off
iscsi 0:off 1:off 2:off 3:on 4:on 5:on 6:off
iscsid 0:off 1:off 2:off 3:on 4:on 5:on 6:off
kudzu 0:off 1:off 2:off 3:on 4:on 5:on 6:off
lvm2-monitor 0:off 1:off 2:off 3:off 4:off 5:off 6:off
mcstrans 0:off 1:off 2:on 3:on 4:on 5:on 6:off
messagebus 0:off 1:off 2:off 3:on 4:on 5:on 6:off
multipathd 0:off 1:off 2:off 3:off 4:off 5:off 6:off
netconsole 0:off 1:off 2:off 3:off 4:off 5:off 6:off
netfs 0:off 1:off 2:off 3:off 4:off 5:off 6:off
netplugd 0:off 1:off 2:off 3:off 4:off 5:off 6:off
network 0:off 1:off 2:on 3:on 4:on 5:on 6:off
ntpd 0:off 1:off 2:off 3:off 4:off 5:off 6:off
psacct 0:off 1:off 2:off 3:off 4:off 5:off 6:off
rawdevices 0:off 1:off 2:off 3:on 4:on 5:on 6:off
rdisc 0:off 1:off 2:off 3:off 4:off 5:off 6:off
restorecond 0:off 1:off 2:on 3:on 4:on 5:on 6:off
rsyslog 0:off 1:off 2:off 3:off 4:off 5:off 6:off
smartd 0:off 1:off 2:on 3:on 4:on 5:on 6:off
sshd 0:off 1:off 2:on 3:on 4:on 5:on 6:off
syslog 0:off 1:off 2:on 3:on 4:on 5:on 6:off
sysstat 0:off 1:off 2:off 3:off 4:off 5:off 6:off
tcsd 0:off 1:off 2:off 3:off 4:off 5:off 6:off
guxin0123
虛擬機(jī)實(shí)體機(jī)全都試過了
沒有安裝wdcp
httpd mysqld什么的服務(wù)全沒安裝
是我下錯(cuò)了包還是怎地 wdOS-1.0-i386.iso
這個(gè)ISO里的安裝
是有四個(gè)安裝選項(xiàng)的,有看嗎?
你安的是哪個(gè)?
如果不知道,再仔細(xì)看下這里
http://www.gps-cemuyi.cn/bbs/thread-2507-1-1.html
guxin0123
一二都試過了
三四沒有試
是32位的?
32位的是有些問題,調(diào)整過了,你再試下
