標(biāo)題: [求助] WDOS 安裝memcache [打印本頁]
作者: 100629338    時(shí)間: 2012-6-30 11:51     標(biāo)題: WDOS 安裝memcache
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 98304
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc static flag -static works... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
creating libtool
config.status: config.h is unchanged
/bin/sh /tmp/memcache-2.2.5/libtool --mode=compile cc -I/www/wdlinux/nginx_php-5.2.17/include/php -I. -I/tmp/memcache-2.2.5 -DPHP_ATOM_INC -I/tmp/memcache-2.2.5/include -I/tmp/memcache-2.2.5/main -I/tmp/memcache-2.2.5 -I/www/wdlinux/nginx_php-5.2.17/include/php -I/www/wdlinux/nginx_php-5.2.17/include/php/main -I/www/wdlinux/nginx_php-5.2.17/include/php/TSRM -I/www/wdlinux/nginx_php-5.2.17/include/php/Zend -I/www/wdlinux/nginx_php-5.2.17/include/php/ext -I/www/wdlinux/nginx_php-5.2.17/include/php/ext/date/lib  -DHAVE_CONFIG_H  -g -O2   -c /tmp/memcache-2.2.5/memcache.c -o memcache.lo
mkdir .libs
cc -I/www/wdlinux/nginx_php-5.2.17/include/php -I. -I/tmp/memcache-2.2.5 -DPHP_ATOM_INC -I/tmp/memcache-2.2.5/include -I/tmp/memcache-2.2.5/main -I/tmp/memcache-2.2.5 -I/www/wdlinux/nginx_php-5.2.17/include/php -I/www/wdlinux/nginx_php-5.2.17/include/php/main -I/www/wdlinux/nginx_php-5.2.17/include/php/TSRM -I/www/wdlinux/nginx_php-5.2.17/include/php/Zend -I/www/wdlinux/nginx_php-5.2.17/include/php/ext -I/www/wdlinux/nginx_php-5.2.17/include/php/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/memcache-2.2.5/memcache.c  -fPIC -DPIC -o .libs/memcache.o
/tmp/memcache-2.2.5/memcache.c:34:18: error: zlib.h: No such file or directory
/tmp/memcache-2.2.5/memcache.c: In function ?.hp_memcache_init_globals?.
/tmp/memcache-2.2.5/memcache.c:255: error: ?._DEFAULT_COMPRESSION?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:255: error: (Each undeclared identifier is reported only once
/tmp/memcache-2.2.5/memcache.c:255: error: for each function it appears in.)
/tmp/memcache-2.2.5/memcache.c: In function ?.mc_compress?.
/tmp/memcache-2.2.5/memcache.c:839: error: ?._OK?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:846: error: ?._MEM_ERROR?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:849: error: ?._BUF_ERROR?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:852: error: ?._STREAM_ERROR?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c: In function ?.mc_uncompress?.
/tmp/memcache-2.2.5/memcache.c:876: error: ?._BUF_ERROR?.undeclared (first use in this function)
/tmp/memcache-2.2.5/memcache.c:878: error: ?._OK?.undeclared (first use in this function)
make: *** [memcache.lo] Error 1
extension=memcache.so
Starting httpd: (98)Address already in use: make_sock: could not bind to address [::]:80
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
                                                           [FAILED]
memcache install is OK
[root@wdOS ~]#
作者: 100629338    時(shí)間: 2012-6-30 11:52
但是 WDCP 后臺(tái)顯示為 啟動(dòng)
程序中無法啟用
作者: admin    時(shí)間: 2012-7-1 20:34
重起一下系統(tǒng)
作者: vabcv    時(shí)間: 2012-7-18 04:00
重起 也沒有啊
作者: admin    時(shí)間: 2012-7-18 10:18
32還是64,是哪個(gè)環(huán)境?
