標題:
系統(tǒng)隔一天自動死機,不能遠程
linaiwei
2012-8-2 20:56
標題:
本帖最后由 linaiwei 于 2012-8-2 20:58 編輯
系統(tǒng)次次都會自動死機!用的是hyper-v 裝的是centos6.3 64位!裝的是wdcp最新版 用一天系統(tǒng)就死一次機!連ssh都連不上,但有時可以ping得通,內存1G cpu雙核 5620 這是部分系統(tǒng)日志請問能看出什么問題嗎?
從
Aug 2 11:21:56 localhost pure-ftpd: (ydwcom@183.2.139.214) [INFO] 登出.
Aug 2 14:31:41 localhost kernel: INFO: task httpd:3993 blocked for more than 120 seconds.
復制代碼
這里開始好像就有問題了!
Aug 1 01:08:10 localhost avahi-daemon[951]: New relevant interface eth0.IPv4 for mDNS.
Aug 1 01:08:10 localhost avahi-daemon[951]: Network interface enumeration completed.
Aug 1 01:08:10 localhost avahi-daemon[951]: Registering new address record for fe80::215:5dff:fea2:ef00 on eth0.*.
Aug 1 01:08:10 localhost avahi-daemon[951]: Registering new address record for 116.255.163.165 on eth0.IPv4.
Aug 1 01:08:10 localhost avahi-daemon[951]: Registering HINFO record with values 'X86_64'/'LINUX'.
Aug 1 01:08:11 localhost avahi-daemon[951]: Server startup complete. Host name is linux.local. Local service cookie is 163269946.
Aug 1 01:08:12 localhost avahi-daemon[951]: Service "linux" (/services/ssh.service) successfully established.
Aug 2 11:11:06 localhost pure-ftpd: (?@183.2.139.214) [INFO] 自 183.2.139.214 的新連接
Aug 2 11:11:06 localhost pure-ftpd: (?@183.2.139.214) [INFO] ydwcom 現(xiàn)在登錄
Aug 2 11:20:17 localhost pure-ftpd: (
) [NOTICE] /home/web/ydwcom//public_html/setup.zip 上傳了 (29299674 bytes, 52.69KB/sec)
) [INFO] 登出.
Aug 2 14:31:41 localhost kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 2 14:31:41 localhost kernel: httpd D 0000000000000001 0 3993 1208 0x00000080
Aug 2 14:31:41 localhost kernel: ffff880005499e38 0000000000000082 0000000000000000 ffff88000549ba40
Aug 2 14:31:41 localhost kernel: ffff880006173c68 ffff880006172288 ffff880005499df8 ffffffff8113fe04
Aug 2 14:31:41 localhost kernel: ffff880037eb1058 ffff880005499fd8 000000000000fb88 ffff880037eb1058
Aug 2 14:31:41 localhost kernel: Call Trace:
Aug 2 14:31:41 localhost kernel: [<ffffffff8113fe04>] ? handle_mm_fault+0x1e4/0x2b0
Aug 2 14:31:41 localhost kernel: [<ffffffff814fee8e>] __mutex_lock_slowpath+0x13e/0x180
Aug 2 14:31:41 localhost kernel: [<ffffffff814fed2b>] mutex_lock+0x2b/0x50
Aug 2 14:31:41 localhost kernel: [<ffffffffa0076f60>] ext4_llseek+0x60/0x110 [ext4]
Aug 2 14:31:41 localhost kernel: [<ffffffff81179c2a>] vfs_llseek+0x3a/0x40
Aug 2 14:31:41 localhost kernel: [<ffffffff8117b3e6>] sys_lseek+0x66/0x80
Aug 2 14:31:41 localhost kernel: [<ffffffff8100b0f2>] system_call_fastpath+0x16/0x1b
Aug 2 14:31:41 localhost kernel: INFO: task httpd:4021 blocked for more than 120 seconds.
Aug 2 14:31:41 localhost kernel: httpd D 0000000000000001 0 4021 1208 0x00000080
Aug 2 14:31:41 localhost kernel: ffff8800180fde38 0000000000000082 ffff8800181bb5f8 ffff88000b366780
Aug 2 14:31:41 localhost kernel: ffff8800180f8c68 ffff880018109288 ffff8800180fddf8 ffffffff8113fe04
Aug 2 14:31:41 localhost kernel: ffff880018163058 ffff8800180fdfd8 000000000000fb88 ffff880018163058
Aug 2 14:31:41 localhost kernel: [<ffffffff8104452c>] ? __do_page_fault+0x1ec/0x480
Aug 2 14:31:41 localhost kernel: INFO: task httpd:4058 blocked for more than 120 seconds.
Aug 2 14:31:41 localhost kernel: httpd D 0000000000000000 0 4058 1208 0x00000080
Aug 2 14:31:41 localhost kernel: ffff88000e777cc8 0000000000000086 0000000000000000 0000000500000004
Aug 2 14:31:41 localhost kernel: 0000000000000005 ffff88000e777d38 ffff88003ebc20c0 ffff88000e777e28
Aug 2 14:31:41 localhost kernel: ffff880005fa9058 ffff88000e777fd8 000000000000fb88 ffff880005fa9058
Aug 2 14:31:41 localhost kernel: [<ffffffff81193627>] ? __d_lookup+0xa7/0x150
Aug 2 14:31:41 localhost kernel: [<ffffffff81179868>] do_truncate+0x58/0xa0
Aug 2 14:31:41 localhost kernel: [<ffffffff8121429f>] ? security_inode_permission+0x1f/0x30
Aug 2 14:31:41 localhost kernel: [<ffffffff8118c269>] do_filp_open+0x829/0xd60
Aug 2 14:31:41 localhost kernel: [<ffffffff81198182>] ? alloc_fd+0x92/0x160
Aug 2 14:31:41 localhost kernel: [<ffffffff81178639>] do_sys_open+0x69/0x140
Aug 2 14:31:41 localhost kernel: [<ffffffff81178750>] sys_open+0x20/0x30
Aug 2 14:31:41 localhost kernel: INFO: task httpd:4112 blocked for more than 120 seconds.
Aug 2 14:31:41 localhost kernel: httpd D 0000000000000001 0 4112 1208 0x00000080
Aug 2 14:31:41 localhost kernel: ffff88000f421e38 0000000000000086 0000000000000000 ffff88000b693300
Aug 2 14:31:41 localhost kernel: ffff88000f43fc38 ffff88000f43e288 ffff88000f421df8 ffffffff8113fe04
Aug 2 14:31:41 localhost kernel: ffff88000f5b1af8 ffff88000f421fd8 000000000000fb88 ffff88000f5b1af8
Aug 2 14:31:41 localhost kernel: INFO: task httpd:4115 blocked for more than 120 seconds.
Aug 2 14:31:41 localhost kernel: httpd D 0000000000000000 0 4115 1208 0x00000080
Aug 2 14:31:41 localhost kernel: ffff880004789e38 0000000000000082 0000000000000000 ffff88000478c340
Aug 2 14:31:41 localhost kernel: ffff88000478f098 ffff88000478e000 ffff880004789df8 ffffffff8113fe04
Aug 2 14:31:41 localhost kernel: ffff8800048e1098 ffff880004789fd8 000000000000fb88 ffff8800048e1098
Aug 2 14:31:42 localhost kernel: [<ffffffff8117b3e6>] sys_lseek+0x66/0x80
Aug 2 14:31:42 localhost kernel: [<ffffffff8100b0f2>] system_call_fastpath+0x16/0x1b
Aug 2 14:31:42 localhost kernel: INFO: task httpd:4116 blocked for more than 120 seconds.
Aug 2 14:31:42 localhost kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 2 14:31:42 localhost kernel: httpd D 0000000000000001 0 4116 1208 0x00000080
linaiwei
2012-8-2 20:57
Aug 2 14:31:42 localhost kernel: ffff88000466de38 0000000000000082 0000000000000000 ffff88000478d940
Aug 2 14:31:42 localhost kernel: ffff8800047a6c68 ffff8800047a5288 ffff88000466ddf8 ffffffff8113fe04
Aug 2 14:31:42 localhost kernel: ffff88000466a5f8 ffff88000466dfd8 000000000000fb88 ffff88000466a5f8
Aug 2 14:31:42 localhost kernel: Call Trace:
Aug 2 14:31:42 localhost kernel: [<ffffffff8113fe04>] ? handle_mm_fault+0x1e4/0x2b0
Aug 2 14:31:42 localhost kernel: [<ffffffff814fee8e>] __mutex_lock_slowpath+0x13e/0x180
Aug 2 14:31:42 localhost kernel: [<ffffffff814fed2b>] mutex_lock+0x2b/0x50
Aug 2 14:31:42 localhost kernel: [<ffffffffa0076f60>] ext4_llseek+0x60/0x110 [ext4]
Aug 2 14:31:42 localhost kernel: [<ffffffff81179c2a>] vfs_llseek+0x3a/0x40
Aug 2 14:31:42 localhost kernel: INFO: task httpd:4215 blocked for more than 120 seconds.
Aug 2 14:31:42 localhost kernel: httpd D 0000000000000000 0 4215 1208 0x00000080
Aug 2 14:31:42 localhost kernel: ffff88000c155cc8 0000000000000086 ffff88000c3c0029 0000000500000004
Aug 2 14:31:42 localhost kernel: 0000000000000005 ffff88000c155d38 ffff88003ebc20c0 ffff88000c155e28
Aug 2 14:31:42 localhost kernel: ffff88000f94dab8 ffff88000c155fd8 000000000000fb88 ffff88000f94dab8
Aug 2 14:31:42 localhost kernel: [<ffffffff8109a9f1>] ? in_group_p+0x31/0x40
Aug 2 14:31:42 localhost kernel: [<ffffffff81193627>] ? __d_lookup+0xa7/0x150
Aug 2 14:31:42 localhost kernel: [<ffffffff81179868>] do_truncate+0x58/0xa0
Aug 2 14:31:42 localhost kernel: [<ffffffff8121429f>] ? security_inode_permission+0x1f/0x30
Aug 2 14:31:42 localhost kernel: [<ffffffff8118c269>] do_filp_open+0x829/0xd60
Aug 2 14:31:42 localhost kernel: [<ffffffff81198182>] ? alloc_fd+0x92/0x160
Aug 2 14:31:42 localhost kernel: [<ffffffff81178639>] do_sys_open+0x69/0x140
Aug 2 14:31:42 localhost kernel: [<ffffffff81178750>] sys_open+0x20/0x30
Aug 2 14:31:42 localhost kernel: INFO: task httpd:4219 blocked for more than 120 seconds.
Aug 2 14:31:42 localhost kernel: httpd D 0000000000000001 0 4219 1208 0x00000080
Aug 2 14:31:42 localhost kernel: ffff88003d525cc8 0000000000000086 0000000000000000 0000000500000004
Aug 2 14:31:42 localhost kernel: 0000000000000005 ffff88003d525d38 ffff88003ebc20c0 ffff88003d525e28
Aug 2 14:31:42 localhost kernel: ffff88000f8ef058 ffff88003d525fd8 000000000000fb88 ffff88000f8ef058
Aug 2 14:31:42 localhost kernel: INFO: task httpd:4221 blocked for more than 120 seconds.
Aug 2 14:31:42 localhost kernel: httpd D 0000000000000001 0 4221 1208 0x00000080
Aug 2 14:31:42 localhost kernel: ffff88003d507cc8 0000000000000082 0000000000000000 0000000500000004
Aug 2 14:31:42 localhost kernel: 0000000000000005 ffff88003d507d38 ffff88003ebc20c0 ffff88003d507e28
Aug 2 14:31:42 localhost kernel: ffff880010ccfaf8 ffff88003d507fd8 000000000000fb88 ffff880010ccfaf8
Aug 2 14:33:40 localhost kernel: INFO: task httpd:3141 blocked for more than 120 seconds.
Aug 2 14:33:40 localhost kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 2 14:33:40 localhost kernel: httpd D 0000000000000001 0 3141 1208 0x00000080
Aug 2 14:33:40 localhost kernel: ffff88003c503cc8 0000000000000086 0000000000000000 0000000500000004
Aug 2 14:33:40 localhost kernel: 0000000000000005 ffff88003c503d38 ffff88003ebc20c0 ffff88003c503e28
Aug 2 14:33:40 localhost kernel: ffff88000714f098 ffff88003c503fd8 000000000000fb88 ffff88000714f098
Aug 2 14:33:40 localhost kernel: Call Trace:
Aug 2 14:33:40 localhost kernel: [<ffffffff814fee8e>] __mutex_lock_slowpath+0x13e/0x180
Aug 2 14:33:40 localhost kernel: [<ffffffff81193627>] ? __d_lookup+0xa7/0x150
Aug 2 14:33:40 localhost kernel: [<ffffffff814fed2b>] mutex_lock+0x2b/0x50
Aug 2 14:33:40 localhost kernel: [<ffffffff81179868>] do_truncate+0x58/0xa0
Aug 2 14:33:40 localhost kernel: [<ffffffff8121429f>] ? security_inode_permission+0x1f/0x30
Aug 2 14:33:40 localhost kernel: [<ffffffff8118c269>] do_filp_open+0x829/0xd60
Aug 2 14:33:40 localhost kernel: [<ffffffff81198182>] ? alloc_fd+0x92/0x160
Aug 2 14:33:40 localhost kernel: [<ffffffff81178639>] do_sys_open+0x69/0x140
Aug 2 14:33:40 localhost kernel: [<ffffffff81178750>] sys_open+0x20/0x30
Aug 2 14:33:40 localhost kernel: [<ffffffff8100b0f2>] system_call_fastpath+0x16/0x1b
Aug 2 14:50:26 localhost kernel: httpd invoked oom-killer: gfp_mask=0x200da, order=0, oom_adj=0, oom_score_adj=0
Aug 2 14:50:26 localhost kernel: httpd cpuset=/ mems_allowed=0
Aug 2 14:50:26 localhost kernel: Pid: 4407, comm: httpd Not tainted 2.6.32-279.el6.x86_64 #1
Aug 2 14:50:26 localhost kernel: Call Trace:
Aug 2 14:50:26 localhost kernel: [<ffffffff810c4971>] ? cpuset_print_task_mems_allowed+0x91/0xb0
Aug 2 14:50:26 localhost kernel: [<ffffffff811170e0>] ? dump_header+0x90/0x1b0
Aug 2 14:50:26 localhost kernel: [<ffffffff812146fc>] ? security_real_capable_noaudit+0x3c/0x70
Aug 2 14:50:26 localhost kernel: [<ffffffff81117562>] ? oom_kill_process+0x82/0x2a0
Aug 2 14:50:26 localhost kernel: [<ffffffff811174a1>] ? select_bad_process+0xe1/0x120
Aug 2 14:50:26 localhost kernel: [<ffffffff811179a0>] ? out_of_memory+0x220/0x3c0
Aug 2 14:50:27 localhost kernel: [<ffffffff811276be>] ? __alloc_pages_nodemask+0x89e/0x940
Aug 2 14:50:27 localhost kernel: [<ffffffff81092110>] ? wake_bit_function+0x0/0x50
Aug 2 14:50:27 localhost kernel: [<ffffffff8115c2da>] ? alloc_pages_vma+0x9a/0x150
Aug 2 14:50:27 localhost kernel: [<ffffffff8114fcf2>] ? read_swap_cache_async+0xf2/0x150
Aug 2 14:50:27 localhost kernel: [<ffffffff81150709>] ? valid_swaphandles+0x69/0x150
Aug 2 14:50:27 localhost kernel: [<ffffffff8114fdd7>] ? swapin_readahead+0x87/0xc0
Aug 2 14:50:27 localhost kernel: [<ffffffff8113f7db>] ? handle_pte_fault+0x70b/0xb50
Aug 2 14:50:27 localhost kernel: [<ffffffff8113fe04>] ? handle_mm_fault+0x1e4/0x2b0
Aug 2 14:50:27 localhost kernel: [<ffffffff81044479>] ? __do_page_fault+0x139/0x480
Aug 2 14:50:27 localhost kernel: [<ffffffff8100988e>] ? __switch_to+0x26e/0x320
Aug 2 14:50:27 localhost kernel: [<ffffffff814fd830>] ? thread_return+0x4e/0x76e
Aug 2 14:50:27 localhost kernel: [<ffffffff81142b4e>] ? remove_vma+0x6e/0x90
Aug 2 14:50:27 localhost kernel: [<ffffffff8150326e>] ? do_page_fault+0x3e/0xa0
Aug 2 14:50:27 localhost kernel: [<ffffffff81500625>] ? page_fault+0x25/0x30
Aug 2 14:50:27 localhost kernel: Mem-Info:
Aug 2 14:50:27 localhost kernel: Node 0 DMA per-cpu:
linaiwei
2012-8-2 20:57
Aug 2 14:50:27 localhost kernel: CPU 0: hi: 0, btch: 1 usd: 0
Aug 2 14:50:27 localhost kernel: CPU 1: hi: 0, btch: 1 usd: 0
Aug 2 14:50:27 localhost kernel: Node 0 DMA32 per-cpu:
Aug 2 14:50:27 localhost kernel: CPU 0: hi: 186, btch: 31 usd: 100
Aug 2 14:50:27 localhost kernel: CPU 1: hi: 186, btch: 31 usd: 141
Aug 2 14:50:27 localhost kernel: active_anon:69898 inactive_anon:70468 isolated_anon:5696
Aug 2 14:50:27 localhost kernel: active_file:128 inactive_file:184 isolated_file:32
Aug 2 14:50:27 localhost kernel: unevictable:0 dirty:0 writeback:315 unstable:0
Aug 2 14:50:27 localhost kernel: free:12584 slab_reclaimable:3514 slab_unreclaimable:22946
Aug 2 14:50:27 localhost kernel: mapped:184 shmem:60 pagetables:55071 bounce:0
Aug 2 14:50:27 localhost kernel: Node 0 DMA free:4616kB min:664kB low:828kB high:996kB active_anon:3044kB inactive_anon:5348kB active_file:44kB inactive_file:0kB unevictable:0kB isolated(anon):2048kB isolated(file):0kB present:15308kB mlocked:0kB dirty:0kB writeback:68kB mapped:44kB shmem:0kB slab_reclaimable:16kB slab_unreclaimable:84kB kernel_stack:0kB pagetables:292kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:23 all_unreclaimable? no
Aug 2 14:50:27 localhost kernel: lowmem_reserve[]: 0 994 994 994
Aug 2 14:50:27 localhost kernel: Node 0 DMA32 free:45720kB min:44388kB low:55484kB high:66580kB active_anon:276548kB inactive_anon:276524kB active_file:468kB inactive_file:736kB unevictable:0kB isolated(anon):20736kB isolated(file):128kB present:1018016kB mlocked:0kB dirty:0kB writeback:1192kB mapped:692kB shmem:240kB slab_reclaimable:14040kB slab_unreclaimable:91700kB kernel_stack:8280kB pagetables:219992kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:1570 all_unreclaimable? no
Aug 2 14:50:27 localhost kernel: lowmem_reserve[]: 0 0 0 0
Aug 2 14:50:27 localhost kernel: Node 0 DMA: 40*4kB 23*8kB 24*16kB 12*32kB 8*64kB 8*128kB 0*256kB 0*512kB 0*1024kB 1*2048kB 0*4096kB = 4696kB
Aug 2 14:50:27 localhost kernel: Node 0 DMA32: 370*4kB 4354*8kB 334*16kB 1*32kB 1*64kB 1*128kB 1*256kB 1*512kB 1*1024kB 1*2048kB 0*4096kB = 45720kB
Aug 2 14:50:27 localhost kernel: 19780 total pagecache pages
Aug 2 14:50:27 localhost kernel: 19329 pages in swap cache
Aug 2 14:50:27 localhost kernel: Swap cache stats: add 1111656, delete 1092327, find 253004/313925
Aug 2 14:50:27 localhost kernel: Free swap = 0kB
Aug 2 14:50:27 localhost kernel: Total swap = 2097144kB
Aug 2 14:50:27 localhost kernel: 262112 pages RAM
Aug 2 14:50:27 localhost kernel: 8888 pages reserved
Aug 2 14:50:27 localhost kernel: 439937 pages shared
Aug 2 14:50:27 localhost kernel: 229189 pages non-shared
Aug 2 14:50:27 localhost kernel: [ pid ] uid tgid total_vm rss cpu oom_adj oom_score_adj name
Aug 2 14:50:27 localhost kernel: [ 339] 0 339 2728 17 0 -17 -1000 udevd
Aug 2 14:50:27 localhost kernel: [ 911] 0 911 6908 24 1 -17 -1000 auditd
Aug 2 14:50:27 localhost kernel: [ 927] 0 927 62269 68 0 0 0 rsyslogd
Aug 2 14:50:27 localhost kernel: [ 940] 81 940 5349 16 0 0 0 dbus-daemon
Aug 2 14:50:27 localhost kernel: [ 951] 70 951 6914 19 0 0 0 avahi-daemon
Aug 2 14:50:27 localhost kernel: [ 952] 70 952 6914 11 0 0 0 avahi-daemon
Aug 2 14:50:27 localhost kernel: [ 983] 0 983 16016 17 0 -17 -1000 sshd
Aug 2 14:50:27 localhost kernel: [ 997] 0 997 27555 18 0 0 0 mysqld_safe
Aug 2 14:50:27 localhost kernel: [ 1188] 27 1188 299423 10185 0 0 0 mysqld
Aug 2 14:50:27 localhost kernel: [ 1189] 0 1189 20078 62 0 0 0 sendmail
Aug 2 14:50:27 localhost kernel: [ 1197] 51 1197 19009 16 1 0 0 sendmail
Aug 2 14:50:27 localhost kernel: [ 1208] 0 1208 32283 605 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 1216] 0 1216 37753 15 0 0 0 pure-ftpd
Aug 2 14:50:27 localhost kernel: [ 1229] 0 1229 27917 32 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 1237] 0 1237 29301 42 1 0 0 crond
Aug 2 14:50:27 localhost kernel: [ 1251] 0 1251 16855 19 0 0 0 login
Aug 2 14:50:27 localhost kernel: [ 1253] 0 1253 1014 16 0 0 0 mingetty
Aug 2 14:50:27 localhost kernel: [ 1255] 0 1255 1014 16 0 0 0 mingetty
Aug 2 14:50:27 localhost kernel: [ 1257] 0 1257 1014 16 1 0 0 mingetty
Aug 2 14:50:27 localhost kernel: [ 1259] 0 1259 1014 16 0 0 0 mingetty
Aug 2 14:50:27 localhost kernel: [ 1262] 0 1262 1014 16 0 0 0 mingetty
Aug 2 14:50:27 localhost kernel: [ 1268] 0 1268 2727 16 0 -17 -1000 udevd
Aug 2 14:50:27 localhost kernel: [ 1269] 0 1269 2727 16 1 -17 -1000 udevd
Aug 2 14:50:27 localhost kernel: [ 1270] 999 1270 28494 20 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 1274] 0 1274 258406 17 0 0 0 console-kit-dae
Aug 2 14:50:27 localhost kernel: [ 1341] 0 1341 28633 19 1 0 0 bash
Aug 2 14:50:27 localhost kernel: [ 1359] 999 1359 29146 20 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3025] 1000 3025 34545 299 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3040] 1000 3040 35908 298 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3041] 1000 3041 33763 299 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3043] 1000 3043 33676 300 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3054] 1000 3054 34294 299 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3070] 1000 3070 34661 297 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3073] 1000 3073 34301 299 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3083] 1000 3083 34739 300 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3089] 1000 3089 34585 300 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3094] 1000 3094 34341 299 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3099] 1000 3099 34329 297 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3100] 1000 3100 34279 297 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3103] 1000 3103 34738 297 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3105] 1000 3105 33766 297 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3113] 1000 3113 34218 298 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3115] 1000 3115 34908 299 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3125] 1000 3125 35226 298 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3128] 1000 3128 33716 299 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3135] 1000 3135 34150 300 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3141] 1000 3141 34275 758 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3144] 1000 3144 34156 296 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3364] 1000 3364 34172 300 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3393] 1000 3393 34446 300 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3394] 1000 3394 34165 301 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3395] 1000 3395 34268 306 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3426] 1000 3426 32317 522 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3427] 1000 3427 34251 492 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3428] 1000 3428 32317 522 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3429] 1000 3429 35208 471 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3430] 1000 3430 33856 489 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3431] 1000 3431 34251 486 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3432] 1000 3432 34506 492 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3434] 1000 3434 35147 474 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3435] 1000 3435 34506 478 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3436] 1000 3436 32317 522 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3437] 1000 3437 35088 476 1 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3438] 1000 3438 34568 490 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3439] 1000 3439 34251 492 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3440] 1000 3440 34251 492 0 0 0 httpd
Aug 2 14:50:27 localhost kernel: [ 3441] 1000 3441 34686 477 1 0 0 httpd
2012-8-3 11:09
重裝換一個系統(tǒng)版本試試
yjfnqtvb
2012-8-7 11:42
曾經在自己機器上裝過6.0 32bit的,進入系統(tǒng)一分鐘不到就會出現(xiàn)內核崩潰的現(xiàn)象。
qianglong
2012-8-7 14:44
檢查下硬件有沒有問題
