標(biāo)題: [求助] 無法編譯安裝 MYSQL ,繼續(xù)求助, [打印本頁]
作者: tibbs    時間: 2012-10-15 20:40     標(biāo)題: 無法編譯安裝 MYSQL ,繼續(xù)求助,
本帖最后由 tibbs 于 2012-10-15 21:01 編輯
installing mysql...
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking how to create a ustar tar archive... gnutar
checking for style of include used by make... GNU
checking for gcc... no
checking for cc... no
configure: error: in `/root/lanmp/mysql-5.1.63':
checking for cl.exe... no
大便6.0系統(tǒng)
  VPS 默認(rèn)版本,未裝 MYSQL
發(fā)現(xiàn)是未裝  GCC 等
apt-get install build-essential
上面問題解決可是出現(xiàn)下面問題
../cmd-line-utils/libedit/libedit.a(terminal.o): In function `terminal_move_to_line':
/root/lanmp/mysql-5.1.63/cmd-line-utils/libedit/terminal.c:519: undefined reference to `tgoto'
/root/lanmp/mysql-5.1.63/cmd-line-utils/libedit/terminal.c:532: undefined reference to `tgoto'
make[2]: *** [mysql] Error 1
make[2]: Leaving directory `/root/lanmp/mysql-5.1.63/client'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/root/lanmp/mysql-5.1.63/client'
make: *** [all-recursive] Error 1
----Install Error: mysql make err -----------
作者: admin    時間: 2012-10-15 22:18
目前不支持大便系統(tǒng),也未在大便系統(tǒng)上測試過
作者: tibbs    時間: 2012-10-16 09:33
逼著我用 CENTOS .
   郁悶啊
  話說  RPM 包貌似沒有 編譯的好
作者: admin    時間: 2012-10-16 11:46
編譯的是比較好,只是比較麻煩
