標題: [教程] 提示 Install Error: wdphp configure err的解決辦法 [打印本頁]
作者: admin    時間: 2012-11-5 23:11     標題: 提示 Install Error: wdphp configure err的解決辦法
發(fā)現(xiàn)在CentOS 5.3的系統(tǒng)下安裝wdcp,會提示如下的錯誤
checking for BZip2 support... no
checking whether to enable calendar conversion support... no
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking if we should use cURL for url streams... no
checking for cURL in default path... found in /usr
checking for cURL 7.10.5 or greater... libcurl 7.15.5
checking for SSL support in libcurl... yes
checking how to run the C preprocessor... gcc -E
checking for openssl support in libcurl... no
checking for gnutls support in libcurl... no
checking for curl_easy_perform in -lcurl... no
configure: error: There is something wrong. Please check config.log for more information.
----Install Error: wdphp configure err -----------
解決辦法
yum install -y libidn-devel
然后再次運行安裝
作者: happyboy    時間: 2013-3-25 17:09
沙發(fā)留名馬克
