標(biāo)題: [求助] 安裝mysqli時(shí)出錯(cuò) [打印本頁]
作者: linaiwei    時(shí)間: 2012-12-1 17:43     標(biāo)題: 安裝mysqli時(shí)出錯(cuò)
centos6.3的64位最新wdcp版
  1. checking build system type... x86_64-unknown-linux-gnu
  2. checking host system type... x86_64-unknown-linux-gnu
  3. checking target system type... x86_64-unknown-linux-gnu
  4. checking for PHP prefix... /www/wdlinux/nginx_php-5.2.17
  5. checking for PHP includes... -I/www/wdlinux/nginx_php-5.2.17/include/php -I/www/wdlinux/nginx_php-5.2.17/include/php/main -I/www/wdlinux/nginx_php-5.2.17/include/php/TSRM -I/www/wdlinux/nginx_php-5.2.17/include/php/Zend -I/www/wdlinux/nginx_php-5.2.17/include/php/ext -I/www/wdlinux/nginx_php-5.2.17/include/php/ext/date/lib
  6. checking for PHP extension directory... /www/wdlinux/nginx_php-5.2.17/lib/php/extensions/no-debug-non-zts-20060613
  7. checking for PHP installed headers prefix... /www/wdlinux/nginx_php-5.2.17/include/php
  8. checking if debug is enabled... no
  9. checking if zts is enabled... no
  10. checking for re2c... no
  11. configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
  12. checking for gawk... gawk
  13. checking for MySQLi support... yes, shared
  14. checking whether to enable embedded MySQLi support... no
  15. mysql_config not found
  16. configure: error: Please reinstall the mysql distribution
  17. make: *** No targets specified and no makefile found.  Stop.
作者: linaiwei    時(shí)間: 2012-12-1 17:47
沒事了!找到方法了
作者: vspt    時(shí)間: 2012-12-3 21:10
什么方法啊
作者: bayeux    時(shí)間: 2012-12-4 00:08
回復(fù) 3# vspt
   http://www.gps-cemuyi.cn/bbs/thread-4184-1-1.html
