標(biāo)題: [求助] 郵件中經(jīng)常提醒如下安全信息警告是否正常呀? [打印本頁]
作者: latercomer    時(shí)間: 2013-1-6 22:15     標(biāo)題: 郵件中經(jīng)常提醒如下安全信息警告是否正常呀?
在putty中執(zhí)行相關(guān)操作是經(jīng)常提醒
[root@myname ~]# service mysqld stop
Shutting down MySQL. SUCCESS!
You have new mail in /var/spool/mail/root
/var/spool/mail/root中的內(nèi)容是
From root@myname  Sun Jan  6 21:56:23 2013
Return-Path: <root@myname>
Received: from myname (localhost [127.0.0.1])
by myname (8.14.4/8.14.4) with ESMTP id r06DuNah018665
for <root@myname>; Sun, 6 Jan 2013 21:56:23 +0800
Received: (from root@localhost)
by myname (8.14.4/8.14.4/Submit) id r06DuNjQ018662;
Date: Sun, 6 Jan 2013 21:56:23 +0800
Message-Id: <201301061356.r06DuNjQ018662@myname>
To: root@myname
Auto-Submitted: auto-generated
Subject: *** SECURITY information for myname ***
myname : Jan  6 21:56:23 : wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/vhost ; COMMAND=/www/wdlinux/wdphp/bin/php
作者: admin    時(shí)間: 2013-1-7 09:23
這個(gè)是正常的
不過,不應(yīng)該是這個(gè)郵件內(nèi)容
作者: latercomer    時(shí)間: 2013-1-7 18:17
   老大,正常情況應(yīng)該是什么問題,出現(xiàn)這樣的問題,是否需要重裝wdcp呀,或者是系統(tǒng)問題呀,謝謝
作者: admin    時(shí)間: 2013-1-7 23:33
不用重裝
作者: latercomer    時(shí)間: 2013-1-8 09:40
回復(fù) 4# admin
   謝謝老大,辛苦您了
