標(biāo)題: [BUG反饋] wdcp v3 安裝出錯(cuò) [打印本頁(yè)]
作者: chinafla    時(shí)間: 2016-4-20 16:51     標(biāo)題: wdcp v3 安裝出錯(cuò)
Starting httpd (via systemctl):  Job for httpd.service failed because the control process exited with error code. See "systemctl status httpd.service" and "journalctl -xe" for details.
                                                           [FAILED]
Starting nginxd (via systemctl):  Job for nginxd.service failed because the control process exited with error code. See "systemctl status nginxd.service" and "journalctl -xe" for details.
                                                           [FAILED]
安裝之后可以訪問 ip:8080 但是ip 無法訪問
重啟一次服務(wù)器之后 ip, ip:8080 都無法訪問了
作者: chinafla    時(shí)間: 2016-4-20 16:56
                                                           [FAILED]
Starting nginxd (via systemctl):  Warning: nginxd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
                                                           [FAILED]
作者: our0011    時(shí)間: 2016-8-2 12:00
用這個(gè)命令systemctl status httpd.service
紅色字上一行,顯示類似bad user www的話,這樣解決
groupadd www
useradd -g www www
然后service httpd restart,就可以了。
作者: admin    時(shí)間: 2016-8-2 22:48
什么系統(tǒng)
作者: lr9569    時(shí)間: 2016-8-3 15:34
服務(wù)未啟動(dòng)
作者: ksxmu    時(shí)間: 2016-10-28 19:55
請(qǐng)問你們解決了嗎?請(qǐng)解決了的私信我好嗎?我也碰到這個(gè)問題……
作者: yjfnqtvb    時(shí)間: 2016-12-21 08:56
裝的時(shí)候看看版本的系統(tǒng)要求,我撞過一次槍口.
