標(biāo)題: [求助] centos7.2.1511 64位新安裝wdCP v3.0.6 重啟服務(wù)器后pureftpd無(wú)法啟動(dòng) [打印本頁(yè)]
作者: linboy    時(shí)間: 2016-7-15 11:13     標(biāo)題: centos7.2.1511 64位新安裝wdCP v3.0.6 重啟服務(wù)器后pureftpd無(wú)法啟動(dòng)
本帖最后由 linboy 于 2016-7-15 16:34 編輯
手動(dòng)啟動(dòng)提示Starting pureftpd (via systemctl):  Job for pureftpd.service failed because the control process exited with error code. See "systemctl status pureftpd.service" and "journalctl -xe" for details.
systemctl status pureftpd.service提示
pureftpd.service - SYSV: Pure-FTPd is an FTP server daemon based upon Troll-FTPd
   Loaded: loaded (/etc/rc.d/init.d/pureftpd)
   Active: failed (Result: exit-code) since 四 2016-07-14 09:48:01 CST; 38s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 32482 ExecStart=/etc/rc.d/init.d/pureftpd start (code=exited, status=127)
7月 14 09:48:01 localhost.localdomain systemd[1]: Starting SYSV: Pure-FTPd is an FTP server daemon based upon Troll-FTPd...
7月 14 09:48:01 localhost.localdomain pureftpd[32482]: Starting pure-ftpd:
7月 14 09:48:01 localhost.localdomain systemd[1]: pureftpd.service: control process exited, code=exited status=127
7月 14 09:48:01 localhost.localdomain systemd[1]: Failed to start SYSV: Pure-FTPd is an FTP server daemon based upon Troll-FTPd.
7月 14 09:48:01 localhost.localdomain systemd[1]: Unit pureftpd.service entered failed state.
7月 14 09:48:01 localhost.localdomain systemd[1]: pureftpd.service failed.
作者: linboy    時(shí)間: 2016-7-15 11:14
本帖最后由 linboy 于 2016-7-15 16:44 編輯
網(wǎng)上說(shuō)CentOS 7 巨大變動(dòng)之 systemd 取代了 SYSV
這里竟然還這么提示……好悲傷
作者: linboy    時(shí)間: 2016-7-19 09:22
本帖最后由 linboy 于 2016-7-19 09:24 編輯
journalctl -xe
-- Unit session-262.scope has begun starting up.
7月 19 09:11:03 localhost.localdomain sshd[16963]: pam_unix(sshd:session): sessi
7月 19 09:11:08 localhost.localdomain polkitd[598]: Registered Authentication Ag
7月 19 09:11:08 localhost.localdomain systemd[1]: Starting SYSV: Pure-FTPd is an
-- Subject: Unit pureftpd.service has begun start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit pureftpd.service has begun starting up.
7月 19 09:11:08 localhost.localdomain pureftpd[17010]: Starting pure-ftpd:
7月 19 09:11:08 localhost.localdomain systemd[1]: pureftpd.service: control proc
7月 19 09:11:08 localhost.localdomain systemd[1]: Failed to start SYSV: Pure-FTP
-- Subject: Unit pureftpd.service has failed
-- Unit pureftpd.service has failed.
-- The result is failed.
7月 19 09:11:08 localhost.localdomain systemd[1]: Unit pureftpd.service entered
7月 19 09:11:08 localhost.localdomain systemd[1]: pureftpd.service failed.
7月 19 09:11:08 localhost.localdomain polkitd[598]: Unregistered Authentication
lines 2338-2360/2360 (END)
7月 19 09:11:03 localhost.localdomain sshd[16963]: pam_unix(sshd:session): session opened for user root by (uid=0)
7月 19 09:11:08 localhost.localdomain polkitd[598]: Registered Authentication Agent for unix-process:17005:68673095 (system bus name :1.551 [/usr/bin/pkttyagent --notify-fd 5 --fallback], o
7月 19 09:11:08 localhost.localdomain systemd[1]: Starting SYSV: Pure-FTPd is an FTP server daemon based upon Troll-FTPd...
7月 19 09:11:08 localhost.localdomain systemd[1]: pureftpd.service: control process exited, code=exited status=127
7月 19 09:11:08 localhost.localdomain systemd[1]: Failed to start SYSV: Pure-FTPd is an FTP server daemon based upon Troll-FTPd.
7月 19 09:11:08 localhost.localdomain systemd[1]: Unit pureftpd.service entered failed state.
7月 19 09:11:08 localhost.localdomain polkitd[598]: Unregistered Authentication Agent for unix-process:17005:68673095 (system bus name :1.551, object path /org/freedesktop/PolicyKit1/Authen
