標(biāo)題: [求助] 環(huán)境配置問(wèn)題······求助····· [打印本頁(yè)]
作者: yy85661840    時(shí)間: 2011-12-9 09:50     標(biāo)題: 環(huán)境配置問(wèn)題······求助·····
Warning: Cannot modify header information - headers already sent by (output started at /www/web/zhuoyueshiji/public_html/bak/config/config.php:1) in /www/web/zhuoyueshiji/public_html/bak/config/config.php on line 2
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /www/web/zhuoyueshiji/public_html/bak/config/config.php:1) in /www/web/zhuoyueshiji/public_html/bak/config/config.php on line 4
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /www/web/zhuoyueshiji/public_html/bak/config/config.php:1) in /www/web/zhuoyueshiji/public_html/bak/config/config.php on line 4
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /www/web/zhuoyueshiji/public_html/class/NewsType_class.php on line 173
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /www/web/zhuoyueshiji/public_html/class/dbclass.php on line 59
這個(gè) 怎么屏蔽???????
求解············
作者: admin    時(shí)間: 2011-12-9 11:55
后臺(tái)管理 站點(diǎn)管理 PHP設(shè)置 把錯(cuò)誤提示關(guān)掉即可
