標(biāo)題: [求助] 新裝的v3多版本php報(bào)錯(cuò)env: gcc: Permission denied ----Install Error: 5.2.17 - [打印本頁]
作者: xiongshouyue    時(shí)間: 2017-5-25 12:46     標(biāo)題: 新裝的v3多版本php報(bào)錯(cuò)env: gcc: Permission denied ----Install Error: 5.2.17 -
Configuring Zend
checking for bison version... (cached) 2.4.1 (ok)
checking for limits.h... (cached) yes
checking for malloc.h... (cached) yes
checking for unistd.h... (cached) yes
checking for stdarg.h... (cached) yes
checking for sys/time.h... (cached) yes
checking for signal.h... (cached) yes
checking for unix.h... (cached) no
checking for mach-o/dyld.h... (cached) no
checking for dlfcn.h... (cached) yes
checking for size_t... (cached) yes
checking return type of signal handlers... (cached) void
checking for uint... (cached) yes
checking for ulong... (cached) yes
checking for int32_t... yes
checking for uint32_t... yes
checking for vprintf... (cached) yes
checking for 8-bit clean memcmp... (cached) yes
checking for working alloca.h... (cached) yes
checking for alloca... (cached) yes
checking for memcpy... (cached) yes
checking for strdup... (cached) yes
checking for getpid... (cached) yes
checking for kill... (cached) yes
checking for strtod... (cached) yes
checking for strtol... (cached) yes
checking for finite... (cached) yes
checking for fpclass... (cached) no
checking whether sprintf is broken... (cached) no
checking for isfinite... (cached) no
checking for isinf... (cached) yes
checking for isnan... (cached) yes
checking whether fp_except is defined... (cached) no
checking whether dlsym() requires a leading underscore in symbol names... no
checking virtual machine dispatch method... CALL
checking whether to enable thread-safety... no
checking whether to enable inline optimization for GCC... yes
checking whether to enable Zend debugging... no
checking whether to enable Zend multibyte... no
checking for inline... (cached) inline
checking target system is Darwin... no
checking for MM alignment and log values... done
checking for memory allocation using mmap(MAP_ANON)... yes
checking for memory allocation using mmap(/dev/zero)... yes
checking for mremap... (cached) yes
Configuring TSRM
Configuring libtool
checking for ld used by gcc... (cached) /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... (cached) yes
checking for /usr/bin/ld option to reload object files... (cached) -r
checking for BSD-compatible nm... (cached) /usr/bin/nm -B
checking how to recognize dependent libraries... (cached) pass_all
checking for object suffix... (cached) o
checking for executable suffix... (cached) no
checking the maximum length of command line arguments... (cached) 1966080
checking command to parse /usr/bin/nm -B output from gcc object... (cached) ok
checking for objdir... (cached) .libs
checking for ar... (cached) ar
checking for ranlib... (cached) ranlib
checking for strip... (cached) strip
checking if gcc supports -fno-rtti -fno-exceptions... (cached) no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... (cached) yes
checking if gcc static flag -static works... (cached) no
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
(cached) (cached) checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
creating libtool
Generating files
creating ./config.status
creating php5.spec
creating main/build-defs.h
creating scripts/phpize
creating scripts/man1/phpize.1
creating scripts/php-config
creating scripts/man1/php-config.1
creating sapi/cli/php.1
creating sapi/cgi/fpm/fpm_autoconf.h
creating sapi/cgi/fpm/php-fpm.conf
creating main/php_config.h
creating main/internal_functions.c
creating main/internal_functions_cli.c
| License:                                                           |
| This software is subject to the PHP License, available in this     |
| distribution in the file LICENSE.  By continuing this installation |
| process, you are bound by the terms of this license agreement.     |
| the installation process at this point.                            |
Thank you for using PHP.
ln: creating symbolic link `/usr/lib/libmysqlclient.a': File exists
ln: creating symbolic link `/usr/lib/libmysqlclient_r.a': File exists
ln: creating symbolic link `/usr/lib/libmysqlclient_r.so': File exists
ln: creating symbolic link `/usr/lib/libmysqlclient_r.so.18': File exists
ln: creating symbolic link `/usr/lib/libmysqlclient_r.so.18.0.0': File exists
ln: creating symbolic link `/usr/lib/libmysqlclient.so': File exists
ln: creating symbolic link `/usr/lib/libmysqlclient.so.18': File exists
ln: creating symbolic link `/usr/lib/libmysqlclient.so.18.0.0': File exists
ln: creating symbolic link `/usr/lib/libmysqld.a': File exists
ln: creating symbolic link `/usr/lib/libmysqlservices.a': File exists
/bin/sh /root/src/php-5.2.17/libtool --silent --preserve-dup-deps --mode=compile gcc -Iext/date/lib -Iext/date/ -I/root/src/php-5.2.17/ext/date/ -DPHP_ATOM_INC -I/root/src/php-5.2.17/include -I/root/src/php-5.2.17/main -I/root/src/php-5.2.17 -I/root/src/php-5.2.17/ext/date/lib -I/usr/include/libxml2 -I/usr/include/freetype2 -I/root/src/php-5.2.17/ext/mbstring/oniguruma -I/root/src/php-5.2.17/ext/mbstring/libmbfl -I/root/src/php-5.2.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include -I/root/src/php-5.2.17/TSRM -I/root/src/php-5.2.17/Zend    -I/usr/include -g -O2  -c /root/src/php-5.2.17/ext/date/php_date.c -o ext/date/php_date.lo
/bin/sh /root/src/php-5.2.17/libtool --silent --preserve-dup-deps --mode=compile gcc -Iext/date/lib -Iext/date/ -I/root/src/php-5.2.17/ext/date/ -DPHP_ATOM_INC -I/root/src/php-5.2.17/include -I/root/src/php-5.2.17/main -I/root/src/php-5.2.17 -I/root/src/php-5.2.17/ext/date/lib -I/usr/include/libxml2 -I/usr/include/freetype2 -I/root/src/php-5.2.17/ext/mbstring/oniguruma -I/root/src/php-5.2.17/ext/mbstring/libmbfl -I/root/src/php-5.2.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include -I/root/src/php-5.2.17/TSRM -I/root/src/php-5.2.17/Zend    -I/usr/include -g -O2  -c /root/src/php-5.2.17/ext/date/lib/astro.c -o ext/date/lib/astro.lo
make: *** [ext/date/lib/astro.lo] Error 1
make: *** Waiting for unfinished jobs....
make: *** [ext/date/php_date.lo] Error 1
x86_64
CentOS release 6.8 (Final)
----Install Error: 5.2.17 -----------
作者: jzbole    時(shí)間: 2017-5-25 15:11
我是再安裝5.4的時(shí)候,出現(xiàn)這個(gè)問題,不知道你解決了沒有
作者: xiongshouyue    時(shí)間: 2017-6-3 11:43
一直沒有解決。
作者: op3121177    時(shí)間: 2017-6-11 13:32
同樣的問題,5.2時(shí)候出現(xiàn)。還沒解決
作者: admin    時(shí)間: 2017-6-11 21:25
看系統(tǒng)是不是安裝了其它防護(hù)軟件,比如云鎖?
作者: 小小青年    時(shí)間: 2017-6-12 15:21
回復(fù) 5# admin
    告訴你吧,這個(gè)問題,很多都是在線安裝,在線下載的問題,在線解壓報(bào)錯(cuò),很多解壓出來的,不全,或者權(quán)限為1000,把下載的那個(gè)目錄下的文件,刪除,然后再運(yùn)行,就繼續(xù)下載安裝,如果還報(bào)錯(cuò),再繼續(xù)來,這個(gè)問題我提過,但是沒有人理我。弄一下完整的下載包,再解壓安裝。能避免很多問題。
作者: fongx    時(shí)間: 2017-6-29 02:43
admin 發(fā)表于 2017-6-11 21:25
我的就是惡心的云鎖,還卸載不掉,直接 kill 了,世界就平靜了
作者: admin    時(shí)間: 2017-6-29 09:03
出現(xiàn)這個(gè)“env: gcc: Permission denied”提示的,基礎(chǔ)是云鎖或是其它安全軟件導(dǎo)致的
作者: sinwl    時(shí)間: 2017-8-18 16:33
管理員正解,出現(xiàn)這個(gè)問題,卸載云鎖就可以了
