標(biāo)題: [求助] 幫分析下mysql自動(dòng)停止的原因 [打印本頁(yè)]
作者: dnf008    時(shí)間: 2017-6-24 08:10     標(biāo)題: 幫分析下mysql自動(dòng)停止的原因
看網(wǎng)站統(tǒng)計(jì)應(yīng)該是0點(diǎn)左右mysql無(wú)法訪問(wèn)的  7.49我重啟的mysql服務(wù)
之前也有過(guò)一次我是重啟的機(jī)器
沒(méi)升3.2之前好好的,升完之后偶爾會(huì)出現(xiàn) 希望幫忙找出解決方法讓wdcp越做越好
170624  0:31:53 [Note] Plugin 'FEDERATED' is disabled.
170624  0:32:01 InnoDB: The InnoDB memory heap is disabled
170624  0:32:02 InnoDB: Mutexes and rw_locks use GCC atomic builtins
170624  0:32:02 InnoDB: Compressed tables use zlib 1.2.3
170624  0:32:33 InnoDB: Initializing buffer pool, size = 128.0M
170624  0:50:18 InnoDB: Completed initialization of buffer pool
170624  7:49:43 [Note] Plugin 'FEDERATED' is disabled.
170624  7:49:43 InnoDB: The InnoDB memory heap is disabled
170624  7:49:43 InnoDB: Mutexes and rw_locks use GCC atomic builtins
170624  7:49:43 InnoDB: Compressed tables use zlib 1.2.3
170624  7:49:43 InnoDB: Initializing buffer pool, size = 128.0M
170624  7:49:43 InnoDB: Completed initialization of buffer pool
170624  7:49:43 InnoDB: highest supported file format is Barracuda.
170624  7:49:43  InnoDB: Waiting for the background threads to start
170624  7:49:44 InnoDB: 5.5.54 started; log sequence number 1595675
170624  7:49:44 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
170624  7:49:44 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
170624  7:49:44 [Note] Server socket created on IP: '0.0.0.0'.
170624  7:49:44 [Note] Event Scheduler: Loaded 0 events
170624  7:49:44 [Note] /www/wdlinux/mysql-5.5.54/bin/mysqld: ready for connections.
Version: '5.5.54'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
作者: dnf008    時(shí)間: 2017-6-24 08:21
我怎么感覺(jué)是靜安服務(wù)器原因,我銀盤總共才100G這個(gè)虛擬內(nèi)存就占100多
前幾天我靜安的一臺(tái)win系統(tǒng)也是這個(gè)問(wèn)題
圖片附件: 360截圖20170624080959765.jpg (2017-6-24 08:20, 44.58 KB) / 下載次數(shù) 13269
http://www.gps-cemuyi.cn/bbs/attachment.php?aid=7659&k=340cb8c92d0f61aea025f6d15b6bd31f&t=1747281513&sid=1ud9fS
作者: admin    時(shí)間: 2017-6-24 09:58
是單升級(jí)后臺(tái)還是環(huán)境也升級(jí)了?如果只升級(jí)了后臺(tái)wdcp是不會(huì)影響的
只有升級(jí)了mysql,apache這些,才可能和升級(jí)有關(guān)
也有可能是系統(tǒng)原因
