標(biāo)題: [求助] 網(wǎng)站刷新打不開Forbidden-You don't have permission to access / on this server [打印本頁] 作者: 408761034 時(shí)間: 2017-7-27 01:16 標(biāo)題: 網(wǎng)站刷新打不開Forbidden-You don't have permission to access / on this server
我用的騰訊云linux系統(tǒng)自帶的wdcp, 用的apache服務(wù)器,,搭建網(wǎng)站后,網(wǎng)站訪問不正常,如果刷新網(wǎng)站,網(wǎng)站就打會打不開,可是過一會又好了,再刷新,又打不開,很煩!我以為是自己的網(wǎng)站源代碼或者數(shù)據(jù)庫喲問題,于是就源代碼刪除了,用系統(tǒng)默認(rèn)的代碼,可是如果刷新,仍然打不開,提示Forbidden
