# systemctl status httpd.service
出現(xiàn)下面提示
● httpd.service - SYSV: Apache is a World Wide Web server. It is used to serve HTML files and CGI.
Loaded: loaded (/etc/rc.d/init.d/httpd; bad; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2017-08-11 03:17:36 CST; 1min 5s ago
Docs: man:systemd-sysv-generator(8)
Process: 7800 ExecStart=/etc/rc.d/init.d/httpd start (code=exited, status=1/FA ILURE)
Aug 11 03:17:36 iZ28iyawu5tZ systemd[1]: Starting SYSV: Apache is a World Wi....
Aug 11 03:17:36 iZ28iyawu5tZ httpd[7800]: Starting httpd: AH00526: Syntax er...:
Aug 11 03:17:36 iZ28iyawu5tZ httpd[7800]: RewriteRule: bad flag delimiters
Aug 11 03:17:36 iZ28iyawu5tZ httpd[7800]: [FAILED]
Aug 11 03:17:36 iZ28iyawu5tZ systemd[1]: httpd.service: control process exit...1
Aug 11 03:17:36 iZ28iyawu5tZ systemd[1]: Failed to start SYSV: Apache is a W....
Aug 11 03:17:36 iZ28iyawu5tZ systemd[1]: Unit httpd.service entered failed s....
Aug 11 03:17:36 iZ28iyawu5tZ systemd[1]: httpd.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
請問大神們這是什么原因啊
