標題:
安裝php錯誤
xjsxiao2004
2017-10-23 18:04
標題:
安裝php錯誤
checking for strtoll... yes
checking for atoll... yes
checking for strftime... (cached) yes
checking which regex library to use... php
checking whether to enable LIBXML support... yes
checking libxml2 install dir... /usr
checking for xml2-config path...
configure: error: xml2-config not found. Please check your libxml2 installation.
make: *** No targets specified and no makefile found. Stop.
x86_64
wdOS 1.0
----Install Error: 5.6.30 -----------
[root@wdOS ~]# yum install -y icu libicu libicu-devel
Loaded plugins: fastestmirror
http://mirrors.163.com/centos/5/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP E rror 404: Not Found
Trying other mirror.
Error: Cannot retrieve repository metadata (repomd.xml) for repository: base. Pl ease verify its path and try again
[root@wdOS ~]#
復制代碼
這個要怎么破
