標題: [求助] 502和504錯誤,求老大現(xiàn)身,實在搞不定 [打印本頁]
作者: 琿琿哥    時間: 2013-5-23 21:29     標題: 502和504錯誤,求老大現(xiàn)身,實在搞不定
本帖最后由 琿琿哥 于 2013-5-23 22:13 編輯
wdcp面板,lanmp時,如果在線人數多了,就502或504了。
lamp時,在線人數多了,就卡死了,不報錯
系統(tǒng)centos 6.3 32位
php5.3.17
512M內存vps,kvm虛擬化
作者: 琿琿哥    時間: 2013-5-23 22:13
回復 1# 琿琿哥
   Jan 07 19:26:01.700196 [NOTICE] fpm_unix_init_main(), line 284: getrlimit(nofile        ): max:1024, cur:1024Jan 07 19:26:01.700549 [NOTICE] fpm_event_init_main(), line 88: libevent: using        epoll
Jan 07 19:26:01.700633 [NOTICE] fpm_init(), line 52: fpm is running, pid 24389
Jan 07 19:26:01.704146 [NOTICE] fpm_children_make(), line 352: child 24390 (pool        default) started
Jan 07 19:26:01.704508 [NOTICE] fpm_children_make(), line 352: child 24391 (pool        default) started
Jan 07 19:26:01.704809 [NOTICE] fpm_children_make(), line 352: child 24392 (pool        default) started
Jan 07 19:26:01.705255 [NOTICE] fpm_children_make(), line 352: child 24393 (pool        default) started
Jan 07 19:26:01.705553 [NOTICE] fpm_children_make(), line 352: child 24394 (pool        default) started
Jan 07 19:26:01.705602 [NOTICE] fpm_event_loop(), line 107: libevent: entering m        ain loop
Jan 07 19:33:02.587317 [NOTICE] fpm_got_signal(), line 56: received SIGTERM
Jan 07 19:33:02.587354 [NOTICE] fpm_pctl(), line 256: switching to 'terminating'        state
Jan 07 19:33:02.587398 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 24394 (pool default)
Jan 07 19:33:02.587409 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 24393 (pool default)
Jan 07 19:33:02.587415 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 24392 (pool default)
Jan 07 19:33:02.587426 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 24391 (pool default)
Jan 07 19:33:02.587434 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 24390 (pool default)
Jan 07 19:33:02.587439 [NOTICE] fpm_pctl_kill_all(), line 181: 5 children are st        ill alive
Jan 07 19:33:02.588665 [NOTICE] fpm_got_signal(), line 48: received SIGCHLD
Jan 07 19:33:02.588731 [WARNING] fpm_children_bury(), line 215: child 24390 (poo        l default) exited on signal 15 SIGTERM after 420.884645 seconds from start
Jan 07 19:33:02.588760 [WARNING] fpm_children_bury(), line 215: child 24391 (poo        l default) exited on signal 15 SIGTERM after 420.884275 seconds from start
Jan 07 19:33:02.588781 [WARNING] fpm_children_bury(), line 215: child 24392 (poo        l default) exited on signal 15 SIGTERM after 420.884002 seconds from start
Jan 07 19:33:02.588806 [WARNING] fpm_children_bury(), line 215: child 24393 (poo        l default) exited on signal 15 SIGTERM after 420.883574 seconds from start
Jan 07 19:33:02.588832 [WARNING] fpm_children_bury(), line 215: child 24394 (poo        l default) exited on signal 15 SIGTERM after 420.883314 seconds from start
Jan 07 19:33:02.588840 [NOTICE] fpm_pctl_exit(), line 81: exiting, bye-bye!
Jan 07 19:44:21.978160 [NOTICE] fpm_unix_init_main(), line 284: getrlimit(nofile        ): max:1024, cur:1024
Jan 07 19:44:21.978353 [NOTICE] fpm_event_init_main(), line 88: libevent: using        epoll
Jan 07 19:44:21.978800 [NOTICE] fpm_init(), line 52: fpm is running, pid 30109
Jan 07 19:44:21.979109 [NOTICE] fpm_children_make(), line 352: child 30111 (pool        default) started
Jan 07 19:44:21.979361 [NOTICE] fpm_children_make(), line 352: child 30112 (pool        default) started
Jan 07 19:44:21.979550 [NOTICE] fpm_children_make(), line 352: child 30113 (pool        default) started
Jan 07 19:44:21.979705 [NOTICE] fpm_children_make(), line 352: child 30114 (pool        default) started
Jan 07 19:44:21.979880 [NOTICE] fpm_children_make(), line 352: child 30115 (pool        default) started
Jan 07 19:44:21.979906 [NOTICE] fpm_event_loop(), line 107: libevent: entering m        ain loop
Jan 07 19:45:09.370060 [NOTICE] fpm_got_signal(), line 56: received SIGTERM
Jan 07 19:45:09.370091 [NOTICE] fpm_pctl(), line 256: switching to 'terminating'        state
Jan 07 19:45:09.370112 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 30115 (pool default)
Jan 07 19:45:09.370120 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 30114 (pool default)
Jan 07 19:45:09.370127 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 30113 (pool default)
Jan 07 19:45:09.370134 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 30112 (pool default)
Jan 07 19:45:09.370151 [NOTICE] fpm_pctl_kill_all(), line 172: sending signal 15        SIGTERM to child 30111 (pool default)
Jan 07 19:45:09.370158 [NOTICE] fpm_pctl_kill_all(), line 181: 5 children are st        ill alive
Jan 07 19:45:09.371094 [NOTICE] fpm_got_signal(), line 48: received SIGCHLD
Jan 07 19:45:09.371143 [WARNING] fpm_children_bury(), line 215: child 30111 (poo        l default) exited on signal 15 SIGTERM after 47.392070 seconds from start
Jan 07 19:45:09.371166 [WARNING] fpm_children_bury(), line 215: child 30112 (poo        l default) exited on signal 15 SIGTERM after 47.391823 seconds from start
Jan 07 19:45:09.371183 [WARNING] fpm_children_bury(), line 215: child 30113 (poo        l default) exited on signal 15 SIGTERM after 47.391654 seconds from start
Jan 07 19:45:09.371201 [WARNING] fpm_children_bury(), line 215: child 30114 (poo        l default) exited on signal 15 SIGTERM after 47.391515 seconds from start
Jan 07 19:45:09.371217 [WARNING] fpm_children_bury(), line 215: child 30115 (poo        l default) exited on signal 15 SIGTERM after 47.391354 seconds from start
Jan 07 19:45:09.371225 [NOTICE] fpm_pctl_exit(), line 81: exiting, bye-bye!
作者: admin    時間: 2013-5-24 08:47
wdcp默認安裝的,不是 php5.3.17 吧?
作者: 琿琿哥    時間: 2013-5-24 10:40
回復 3# admin
按照你們提供的升級教程升級的,因為默認那版本wp會報很多錯誤
作者: ppopcn    時間: 2013-5-26 13:51
512M內存小了點,考慮增加內存吧
作者: zhanjun    時間: 2013-5-29 09:24
感覺是內存小的原因吧
