nginx升級1.4.1問題limit_conn_zone
linaiwei
我把nginx升級為1.4.1后提示limit_zone不支持了!要用limit_conn_zone那我是不是把
#!/bin/bash
# nginx update scripts
# url http://www.gps-cemuyi.cn
# author wdlinux
if [ ! $1 ];then
ver="1.2.9"
else
ver=$1
fi
cd /tmp
wget http://down.wdlinux.cn/in/pcre_ins.sh
sh pcre_ins.sh
wget -c http://nginx.org/download/nginx-$ver.tar.gz
[ $? != 0 ] && echo "down err" && exit
tar zxvf nginx-$ver.tar.gz
cd nginx-$ver
./configure --user=www --group=www --prefix=/www/wdlinux/nginx-$ver --with-http_stub_status_module --with-http_ssl_module
[ $? != 0 ] && echo "configure err" && exit
make
[ $? != 0 ] && echo "make err" && exit
make install
[ $? != 0 ] && echo "make install err" && exit
mv /www/wdlinux/nginx-$ver/conf/nginx.conf /www/wdlinux/nginx-$ver/conf/nginx.conf.default
cp -pR /www/wdlinux/nginx/conf/* /www/wdlinux/nginx-$ver/conf/
service nginxd stop
rm -f /www/wdlinux/nginx
ln -sf /www/wdlinux/nginx-$ver /www/wdlinux/nginx
sed -i '/limit_zone/d' /www/wdlinux/nginx/conf/nginx.conf
service nginxd start
echo
echo
echo "Nginx Update Is OK"
echo "Current Ver Is:$ver"
echo
中的
limit_zone改為
limit_conn_zone
linaiwei
回復(fù)
1#
linaiwei
升級后第次運(yùn)行nginx重起都提示
[root@bogon ~]# service nginxd restart
Stopping nginx: nginx: [emerg] invalid number of arguments in "limit_conn_zone" directive in /www/wdlinux/nginx-1.4.1/conf/nginx.conf:22
[ OK ]
Shutting down php_fpm warning, no pid file found - php-fpm is not running ?
Starting nginx: nginx: [emerg] invalid number of arguments in "limit_conn_zone" directive in /www/wdlinux/nginx/conf/nginx.conf:22
[FAILED]
Starting php_fpm PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) 'zip.so' in Unknown on line 0
done
把nginx.conf文件里的
limit_conn_zone
這行,去掉就行了
