為何一加載magento官方的conf文件nginx就無法重啟
preta
我在 domain.conf 中 include 官方的 conf 文件 根目錄下的nginx.conf.sample 重啟 nginx就無效 一恢復(fù)原來的就可以了
## Example configuration:
# upstream fastcgi_backend {
# # use tcp connection
# # server 127.0.0.1:9000;
# # or socket
# server unix:/var/run/php5-fpm.sock;
# server unix:/var/run/php/php7.0-fpm.sock;
# server {
# listen 80;
# server_name mage.dev;
# set $MAGE_ROOT /var/www/magento2;
# include /vagrant/magento2/nginx.conf.sample;
## Optional override of deployment mode. We recommend you use the
## command 'bin/magento deploy:mode:set' to switch modes instead.
## set $MAGE_MODE default; # or production or developer
## If you set MAGE_MODE in server config, you must pass the variable into the
## PHP entry point blocks, which are indicated below. You can pass
## it in using:
## fastcgi_param MAGE_MODE $MAGE_MODE;
## In production mode, you should uncomment the 'expires' directive in the /static/ location block
root $MAGE_ROOT/pub;
index index.php;
autoindex off;
charset UTF-8;
error_page 404 403 = /errors/404.php;
#add_header "X-UA-Compatible" "IE=Edge";
# PHP entry point for setup application
location ~* ^/setup($|/) {
root $MAGE_ROOT;
location ~ ^/setup/index.php {
fastcgi_pass fastcgi_backend;
fastcgi_param PHP_FLAG "session.auto_start=off \n suhosin.session.cryptua=off";
fastcgi_param PHP_VALUE "memory_limit=756M \n max_execution_time=600";
fastcgi_read_timeout 600s;
fastcgi_connect_timeout 600s;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
include fastcgi_params;
location ~ ^/setup/(?!pub/). {
deny all;
location ~ ^/setup/pub/ {
add_header X-Frame-Options "SAMEORIGIN";
# PHP entry point for update application
location ~* ^/update($|/) {
root $MAGE_ROOT;
location ~ ^/update/index.php {
fastcgi_split_path_info ^(/update/index.php)(/.+)$;
fastcgi_param PATH_INFO $fastcgi_path_info;
# Deny everything but index.php
location ~ ^/update/(?!pub/). {
deny all;
location ~ ^/update/pub/ {
location / {
try_files $uri $uri/ /index.php$is_args$args;
location /pub/ {
location ~ ^/pub/media/(downloadable|customer|import|theme_customization/.*\.xml) {
deny all;
alias $MAGE_ROOT/pub/;
location /static/ {
# Uncomment the following line in production mode
# expires max;
# Remove signature of the static files that is used to overcome the browser cache
location ~ ^/static/version {
rewrite ^/static/(version[^/]+/)?(.*)$ /static/$2 last;
location ~* \.(ico|jpg|jpeg|png|gif|svg|js|css|swf|eot|ttf|otf|woff|woff2)$ {
add_header Cache-Control "public";
expires +1y;
if (!-f $request_filename) {
rewrite ^/static/?(.*)$ /static.php?resource=$1 last;
location ~* \.(zip|gz|gzip|bz2|csv|xml)$ {
add_header Cache-Control "no-store";
expires off;
location /media/ {
try_files $uri $uri/ /get.php$is_args$args;
location ~ ^/media/theme_customization/.*\.xml {
deny all;
expires +1y;
expires off;
location /media/customer/ {
deny all;
location /media/downloadable/ {
deny all;
location /media/import/ {
deny all;
# PHP entry point for main application
location ~ (index|get|static|report|404|503|health_check)\.php$ {
try_files $uri =404;
fastcgi_buffers 1024 4k;
fastcgi_param PHP_VALUE "memory_limit=756M \n max_execution_time=18000";
gzip on;
gzip_disable "msie6";
gzip_comp_level 6;
gzip_min_length 1100;
gzip_buffers 16 8k;
gzip_proxied any;
gzip_types
text/plain
text/css
text/js
text/xml
text/javascript
application/javascript
application/x-javascript
application/json
application/xml
application/xml+rss
image/svg+xml;
gzip_vary on;
# Banned locations (only reached if the earlier PHP entry point regexes don't match)
location ~* (\.php$|\.htaccess$|\.git) {
deny all;
