標(biāo)題: [求助] 阿里云ecsCentOS 7.4 64位安裝WDPC3.2問題 [打印本頁]
作者: 易大大    時(shí)間: 2018-10-25 20:00     標(biāo)題: 阿里云ecsCentOS 7.4 64位安裝WDPC3.2問題
1。安裝完成后,沒有顯示HTTPD服務(wù)
2.成功新建站點(diǎn)后,無法通過域名訪問,顯示網(wǎng)絡(luò)連接錯(cuò)誤
3.用命令提示符PING域名和服務(wù)器IP地址均有反饋
4.已經(jīng)重裝了4次了,都是一模一樣。
5.如何解決?是不是服務(wù)器的系統(tǒng)版本過高了?
一下是安裝完成后顯示的
starting...
Shutting down MySQL.                                       [  OK  ]
Starting MySQL..                                           [  OK  ]
Starting nginxd (via systemctl):                           [  OK  ]
Starting memcached (via systemctl):                        [  OK  ]
Starting wdcp (via systemctl):                             [  OK  ]
Starting pureftpd (via systemctl):                         [  OK  ]
Created symlink from /etc/systemd/system/basic.target.wants/iptables.service to /usr/lib/systemd/system/iptables.service.
iptables: Saving firewall rules to /etc/sysconfig/iptables:[  OK  ]
      Congratulations ,lanmp,wdCP install is complete
      visit http://ip
      wdCP http://ip:8080
      more infomation please visit http://www.gps-cemuyi.cn/bbs/
