標(biāo)題: [求助] 執(zhí)行sh in.sh,提示“too many arguments” [打印本頁(yè)]
作者: 夏SAMA    時(shí)間: 2013-7-15 20:44     標(biāo)題: 執(zhí)行sh in.sh,提示“too many arguments”
[ec2-user@webserver wdcp]$ sudo sh in.sh
in.sh: line 8: [: too many arguments
Select Install
        4 install all service
        5 don't install is now
Please Input 1,2,3,4,5:
in.sh中的內(nèi)容是:
  1. #!/bin/bash
  2. ###
  3. if [ $UID != 0 ];then
  4.         echo "You must be root to run the install script."
  5.         exit
  6. fi
  7. if [ $1 == "un" -o $1 == "uninstall" ];then
  8.         service httpd stop
  9.         service nginxd stop
  10.         service mysqld stop
  11.         service pureftpd stop
  12.         service wdapache stop
  13.         mkdir /www/backup
  14.         bf=`date +%Y%m%d`
  15.         tar zcvf /www/backup/mysqlbk_$bf.tar.gz /www/wdlinux/mysql/var
  16.         rm -fr /www/wdlinux
  17.         rm -f /tmp/*_ins.txt
  18.         reboot
  19.         exit
  20. fi
  21. chmod 755 lanmp.sh
  22. chmod 755 wdcp_ins.sh
  23. ./lanmp.sh | tee lanmp_ins.log
  24. ./wdcp_ins.sh | tee wdcp_ins.log
作者: 夏SAMA    時(shí)間: 2013-7-15 20:49
系統(tǒng)是RedHat ELS 6.4
作者: admin    時(shí)間: 2013-7-16 09:10
能安裝完嗎
作者: marquis    時(shí)間: 2013-7-16 11:54
將"[  ]"替換成"[[  ]]"試試
作者: 夏SAMA    時(shí)間: 2013-7-16 17:29
能安裝完嗎
admin 發(fā)表于 2013-7-16 09:10
我打開in.sh 把最后兩句話分別用sudo執(zhí)行  成功安裝了
將"[  ]"替換成"[[  ]]"試試
marquis 發(fā)表于 2013-7-16 11:54
thx
作者: hkfalcon    時(shí)間: 2013-8-14 21:18
  1. if [ $1 == "un" -o $1 == "uninstall" ];then
修改為:
  1. if [ "$1" == "un" -o "$1" == "uninstall" ];then
可以解決運(yùn)行in.sh出現(xiàn)[: too many arguments錯(cuò)誤。
